Booleans causes holes
All  1-7  8-13
8382.8 In reply to 8382.7
Thank you SO much Michael, your're the best. I am so glad to know this. I'm too tired to fix it right now but I will definitely start trying to figure this out. I have another model with this issue (or two) I will attempt to fix them as well and if I can't figure it out I will post in here again. I'll lurk some more too before i post:)
Also thanks for more terminology like naked edges, i will try and read more about this.
Again really appreciate the time and awesome answer!
Remade all: works fine!
Just a question
What is the use to Flat the "moved lines" and not just vertical extrude the lines bottom not moved?
EDITED: 22 Apr 2017 by PILOU
8382.10 In reply to 8382.9
Flattening it has the added benefit of making the extruded faces able to be handled as analytic plane surfaces which can then get special treatment in things like intersection calculations.
It would also work to extrude the edges directly, it would result though in surfaces that have slanted control points with a parallelogram type shape. It's not like that's horrible but it means they will be generic surfaces and not able to be handled as an analytic plane surface.
So flattening it out just helps to make the end surfaces as simplified as possible.
8382.11 In reply to 8382.10
THX for the infos!
8382.12
I just did this on the first part, and used all the scripts you sent me, thank you so much Michael, you save my life. I really appreciate it. Can't wait to try and fix the other ones!
8382.13 In reply to 8382.12
You're welcome, I'm glad you're able to continue with your modeling!
Show messages: All  1-7  8-13
