Booleans causes holes
All  1-4  5-13
8382.5 In reply to 8382.4
Hey everyone thanks so much for the feedback! I really appreciate it.
I still don't understand a lot of the fundamentals but knowing the difference between a solid and joined surface is very helpful!
Sorry for the short reply, but basically I mean, the mesh WAS a solid, and then at a certain point via booleans or some other reason, when I boolean out anything now, the mesh will create a hole, and the boolean no longer keeps the mesh a solid. I want to boolean out a bunch of surface details and extra form changes. The problem is I cannot go any farther now.
I have had this happen with every solid I have worked with, where at some point while I am working booleans break it. I don't have the proper vocabulary to really describe my problem so I am doing my best.
SO I get that I can still boolean, I just want it to stay a solid all the time. And i don't know at what point it breaks or if it's something I'm doing.
I booleaned this cube, I would ideally want this to be a solid. I know the mesh now longer is a solid but I know that people have had this issue, and could I fix this and make it solid again or fix this in the future?
As I said the person I knew said there is nothing you can do about it but I wanted to see what you guys think. He said he saves a lot because of this.
8382.6 In reply to 8382.5
Hi Swegmang, yes it's possible to repair it but it would be a lot easier if you repaired it right as soon as it became an open surface instead of a closed solid. Don't just continue to do more booleans on the object that isn't a solid because you'll keep on opening more and more holes each of which will need to be filled in order to repair it.
There is a tutorial on object repair techniques here: http://moi3d.com/forum/index.php?webtag=MOI&msg=446.17
To begin with repairing it, first use the select naked edges script that I posted above, it will show you the areas that are open.
First there is a big hole in the front part:
To repair that, you'll need to re-create the cutting line, you do that by copying these curves down (hold down Ctrl and drag on them) and flattening them (switch to the front view and use the edit frame to do a "flat snap" http://moi3d.com/forum/index.php?webtag=MOI&msg=3378.4 ). Also replace any series of multiple lines that are colinear with one single line:
Now that the original 2D planar cutting curve has been restored you can now extrude it up like this:
Now you need to cut the new extrusion with the edges making up the hole, these are the cutting objects:
This will cut the extrusion into 3 pieces, select these outer ones as the pieces to discard:
That will leave you with this trimmed surface:
That's the piece needed to repair the front, select it and the main object and use Edit > Join to glue them together and seal off that hole.
Then there's another area to fix on the opposite side, I'll post about that one next.
8382.7 In reply to 8382.5
Then on the opposite side there are a bunch of naked edges around this filleted area:
It looks like it's these fillets that caused your object to become not solid so that's where the trouble started probably.
See for example these fillets here:
Even though that really looks like 2 fillets with a thin surface between them, that's not what it is - it's actually just 2 fillets with no surface between them, the fillets overshoot past each other by a little bit. So it looks like you used a fillet radius that was just slightly too large to fit in the available space. The fillets were still generated but their ends are not attached to anything.
It would probably be easiest to erase this front protrusion and build it again with a smaller fillet radius. To erase it you can delete all the faces making up that protrusion which will leave a hole, then you can select the edges around the hole and use delete on those too doing an "untrim" (it's covered in that object repair tutorial linked to earlier, also here: http://moi3d.com/forum/index.php?webtag=MOI&msg=444.4) .
That will remove the protrusion so you'll need to rebuild that area:
But now with these steps done your object is back to being a solid and booleans on it should be back to behaving normally again.
I've attached the solid object 3DM file here as repaired_object_3dm.zip .
Hope this helps explain what happened and how it's fixable.
8382.8 In reply to 8382.7
Thank you SO much Michael, your're the best. I am so glad to know this. I'm too tired to fix it right now but I will definitely start trying to figure this out. I have another model with this issue (or two) I will attempt to fix them as well and if I can't figure it out I will post in here again. I'll lurk some more too before i post:)
Also thanks for more terminology like naked edges, i will try and read more about this.
Again really appreciate the time and awesome answer!
Remade all: works fine!
Just a question
What is the use to Flat the "moved lines" and not just vertical extrude the lines bottom not moved?
EDITED: 22 Apr 2017 by PILOU
8382.10 In reply to 8382.9
Flattening it has the added benefit of making the extruded faces able to be handled as analytic plane surfaces which can then get special treatment in things like intersection calculations.
It would also work to extrude the edges directly, it would result though in surfaces that have slanted control points with a parallelogram type shape. It's not like that's horrible but it means they will be generic surfaces and not able to be handled as an analytic plane surface.
So flattening it out just helps to make the end surfaces as simplified as possible.
8382.11 In reply to 8382.10
THX for the infos!
8382.12
I just did this on the first part, and used all the scripts you sent me, thank you so much Michael, you save my life. I really appreciate it. Can't wait to try and fix the other ones!
8382.13 In reply to 8382.12
You're welcome, I'm glad you're able to continue with your modeling!
Show messages: All  1-4  5-13
