Smooth cabochon.like surface ?
All  1-3  4-9
8381.4
Hi Karsten thank you for the helpful + instructive file - great ! And David for the link !
Will go through the techniques explained and am sure it will lead to
the smoothest pebbles ever ;-)
8381.5 In reply to 8381.3
Michael, i think i asked awhile back but forgot.
Is there a way for you to look at the spheres points "transforming" after a certain level of manipulation and forcing it to remain? (It transforms into another type of analytical object or something)
Maybe the new geometry library can provide it...
8381.6 In reply to 8381.5
Hi Burr, sorry I'm not really understanding this. What type of analytic surface do you want to get after editing some sphere points?
When you edit the points of a sphere, the original exact sphere is actually replaced by an approximation. That's because the actual exact sphere's control points are not good to squish around because an exact NURBS sphere has "fully multiple knots" (basically corner points) which will form a crease if you move them around individually.
8381.7 In reply to 8381.6
Hi michael,
I'm not looking for a transform. Here's the jist.
I can create a sphere and turn on points and manipulate. (Keeping that initial "round sphere cage" of points) and basically a smooth object, deformed.
At some point, that sphere cage breaks and becomes more of a square "bounding box cage"...
I was wondering if we could "force the no change" with a sphere object, or even make a special case sphere object that would keeps the points the same...
If thats not clear, let me know and i'll make a vid to demonstrate...
8381.8 In reply to 8381.7
Hi Burr, well once you have moved a point it is supposed to stay in its deformed state after that. If you see it reverting to the square bounding box type cage (that's the one for the precise sphere with those "fully multiple knots" in it), that sounds like a bug. Do you have any steps you can show to repeat that?
One thing to note is that you'll only get the "smoothly deformable" type sphere points if the sphere is an untrimmed surface. If it has trim curves on it you'll get the bounding box like points.
8381.9 In reply to 8381.8
Hi michael,
No, it doesnt revert like the bug you described.
Its the point where it changes from the original sphere points that are presented to the square box points.
I thought i rememberd that it happens automatically after some points are moved to some location relatively, but it definitely happens with an edit frame move.
Give me a bit today and i'll make a vid to see if i can illustrate what part i'm talking about.
Show messages: All  1-3  4-9
