Creating custom colours (styles) on start-up
All  1-4  5-6
8359.5 In reply to 8359.4
Hi Brian, you can just use the filename directly instead of calling .getCompactPath().
Current code is like this:
				var filename = moi.geometryDatabase.startupTemplate;
				if ( filename != '' )
					g_TemplateShortName = moi.filesystem.getCompactPath( filename, 29 );
You'd want to switch it to this instead:
					g_TemplateShortName = filename;
Hope that does what you wanted!
8359.6 In reply to 8359.5
Thank you very much Michael.
I also changed line 251 from 18em to 36em
(The path I gave above was not quite correct :-)
Show messages: All  1-4  5-6
