Mesh exported to Zbrush is faceted!
All  1  2-7
8356.2 In reply to 8356.1
Subdivide inside ZBrush!
Or in Moi3D put more subdivisions at the exportation!
8356.3 In reply to 8356.2
I can't subdivide it in Zbrush - gives distorted results :(
EDITED: 22 Mar 2017 by DEFONTEN
8356.4 In reply to 8356.1
Hi Defonten, when you subdivide in Zbrush I think there's an option for whether to apply sub-division smoothing or not. You'll need to have that unchecked when you do the subdivide since it's a regular polygon cage and not a sub-d smoothed polygon cage. I think it's a checkbox labeled SMT (for "smooth").
You can also increase the mesh density during the MoI export by using the "Divide larger than" setting as described here:
http://moi3d.com/forum/index.php?webtag=MOI&msg=2833.5
Also it's just a normal part of the ZBrush display that it shows things flat shaded so you can more easily see the polygon structure while sculpting. If it's that flat shaded look that is bothering you, I think there is a setting under display properties to do smooth drawing instead of faceted drawing for the display: http://docs.pixologic.com/reference-guide/tool/polymesh/display-properties/
Smooth in Edit mode ?
Unified Skin ... Subdivide Edit Smooth...
8356.6 In reply to 8356.5
Thanks a lot Michael, yep, setting "Devide larger than" value to 0.1 did the trick! The problem was that polygon density was too uneven on creases and "flat" areas. Now it's working fine. Thanks a lot!
Size: 1.4 MB, Downloaded: 220 times, Dimensions: 1432x886px
8356.7 In reply to 8356.6
You're welcome Defonten, that is looking great!
Show messages: All  1  2-7
