Question about custom UI
All  1-11  12-20
8332.12 In reply to 8332.11
Hi Ced,
> 1. Where do I change the 'button' behind the font & remove the
> '5 O'clock shadow?' (Can't find the property to change)
You need to look in the SidePane.htm file in a text editor to see how it's structured.
The palettes are made up of 2 pieces, there's a <moi:PaletteHeader> that is the part that holds the tab buttons, and a <moi:PaletteBody> that holds the content of the tab. The buttons themselves are <moi:TabButton> elements inside the header.
> 2. Where do I change the font style? (the CSS font style isn't apparent in DreamWeaver Properties)
The main font is set on the body by the UI engine from a value which can be set in moi.ini, under [UI] UIFontName=
I really don't recommend making all these types of changes though, it will make things difficult for you once the V4 betas start up and there are new releases, you will need to reapply all your changes with every beta release.
8332.13
Michael -
Thank you for the 50 dollar tip - it worked.
I prefer the names on the labels as well as the order - just not the DROP SHADOWS!
How the heck do you get them out? I tried everything (I can write CSS & HTML - however - no luck).
Cheers,
Mortimer
8332.14 In reply to 8332.13
Hi Ced, they aren't drop shadows, they are the <moi:PaletteBody> elements that contain the command buttons. When the palette is not active, the content is hidden and the <moi:PaletteBody> will be small. Basically it's the same thing with border and background that you see when you activate a palette, when a tab is activated the content inside the <moi:PaletteBody> is displayed and then the "drop shadow" grows larger.
If you want to get rid of those you'll need to modify the script code that handles clicking on a palette tab, it's the function HandleTabChange() inside the SidePaneTabs.js file.
8332.15 In reply to 8332.13
Hi Ced, now I remembered that the top part of the border is in the <moi:PaletteHeader> element and then the rest is in the <moi:PaletteBody> .
If you want to remove those, go to moi.css and find the style rules for moi\:PaletteHeader > .PaletteHeaderBackground and moi\:PaletteBody and remove the background-color and border attributes for those 2 things and then there won't be any borders for those things.
8332.16
Ha-ha~!
DISCLAIMER: If you're prone to panic attacks, dizziness, flatulence or have low self-esteem - please read at your own risk and/or seek medical advice:
BEGIN POST
Ladies & gentlemen, and thank you Michael - introducing sick software accompanied by the most lame GUI - gotta love it~
BEAUTIFUL~!
Cheers,
Mamadou Amado
Nice geometric perspective of the right menu!
8332.18
Frenchy,
See? Only a cultured Frenchman has the capacity to appreciate true narcissist work!
Beauty~
EDITED: 1 Mar 2017 by FRACTIONALIST
Size: 392.4 KB, Downloaded: 32 times, Dimensions: 1200x653px
8332.19
At last~! The Moi3d GUI is now - PERFECT in all its glory:
Nevertheless - would like an OPTION CHECKBOX where, if I choose, the folders will ALL REMAIN OPEN instead of 'one-at-a-time' -
8332.20
Yosuke, you may like to add TOOL TIPS to your command menu -
Show messages: All  1-11  12-20
