Hollow Extrude
All  1-5  6-14
8331.6 In reply to 8331.1
Hi
Highlight (select) all the points and use the align tool. That will make them planar.
keith
like suggested make them planar and then extrude.
However, i did a small test with ViaCAD and it's Cover Surface function.
I used Cover Surface on a non-planar closed curve to obtain a non-planar surface,
which then can be used with a boolean diff in MoI.
You may try it out to see if that works for you too.
...or maybe post the green shape and i try to close it with ViaCAD, in case it must be non-planar.
8331.9
Hi SanSingh !
I suggest you to follow Burr's guidelines :) but let me show you an alternative way to put a patch on your object (or something like that)
I try to replicate your profile moving few points
now extrude it
hide the profile curve,select red edges and join them, edges will be sections and rails for sweep
this is resulting surface after sweep
do the same with the back,join all surfaces and you'll obtain a solid
maybe this won't work with your model but in future could be helpful....just an idea ;)
M
8331.10 In reply to 8331.5
Thanks BurrMan, it worked!
Cheers.
Sandeep.
8331.11 In reply to 8331.6
Hello Keith,
thank you for the tip!
Cheers.
Sandeep.
8331.12 In reply to 8331.7
Hello Stefan,
thank you for the file and all the options.
The boolean and difference option worked for me!
Thank you so much!
Cheers.
Sandeep.
8331.13 In reply to 8331.8
Thank you again!
Cheers.
Sandeep.
8331.14 In reply to 8331.9
Hello Mauro,
thank you for going through all that effort to help me out.
BurrMan's suggestion worked. I will also keep your method in mind as an alternative.
Thank you so much! Much appreciated.
Cheers.
Sandeep.
Show messages: All  1-5  6-14
