Generating screenshot with grid
All  1-5  6-11
8318.6 In reply to 8318.5
Hi Brendan, I can't seem to find anything wrong with your file, do you have Illustrator available to test loading into it? MoI writes an older AI v8 type of file which Inkscape does not know how to read, Inkscape can only read newer versions which are the same as PDF format.
Are you able to organize things in Photoshop by color or lineweight instead? If so then you could use PDF format. I'm traveling for this next week and so it's a little difficult for me to examine your file in detail with other programs, I can check it in more detail like loading it into Illustrator next week.
Inkscape can load older AI 8.0 files from MoI, as you can see in my screenshot.
It requires to install UniConvertor or pstoedit, if i remember correctly.
It's long ago since i installed those two programs, so i'm not sure
which one is responsible for allowing Inkscape to load the older AI format.
8318.8 In reply to 8318.7
Hi Stefan, that's right I seem to remember something about that now. It doesn't do it "out of the box" though.
Do you know where you go to find the Inkscape plug-ins to get that set up?
i got them from here:
https://sk1project.net/modules.php?name=Products&product=uniconvertor&op=download
http://www.pstoedit.net
I have read also that the Windows vers. of Inkscape already has UniConvertor support.
Best regards
8318.10 In reply to 8318.9
Hi Stefan,
The Windows version (I've tried with 0.92 rev1 32 bits) of Inkscape will effectively import AI 8 files but we first have to install uniconvertor-1.1.5-win32 from the link you provided.
After installing, it is necessary to apply a patch to connect Uniconvertor to Inkscape.
The patch installation intructions will be in c:\ Program Files (x86)\sK1 Project\uniconvertor-1.1.5\docs\about-patch.html
After that, it will be possible to directly import (select Import - File Type : Adobe Ilustrator 8 and previous) to Inkscape without errors.
Thanks to Michael for remembering it and to Stefan for this link !
It saves from first opening in AI to convert it.
Michel
Hi Michel,
for Mac users they have to compile the source code for UniConverter, but no Inkscape patch was needed, as far as i remember.
Show messages: All  1-5  6-11
