Beretta 9mm
All  1-4  5-18
8312.5 In reply to 8312.2
Thanks Pilou,
will go through the videos and see how to tackle this model.
Cheers!
Sandeep.
8312.6 In reply to 8312.3
Hello Martin, it's not a crazy idea to start with the barrel...
that is where i initially started, but after a week... it just wasn't working out.
Let me have another crack based on the feedback in the forum.
Thanks!
Sandeep.
8312.7 In reply to 8312.4
Thanks Michael, thanks for the link, will have a look!
Cheers.
Sandeep.
8312.8 In reply to 8312.7
Hi
I used your blueprints and made this. Its not 100% accurate and it was not easy!
Size: 45.2 KB, Downloaded: 126 times, Dimensions: 934x846px
8312.9 In reply to 8312.8
Hello Keith!
Thank you for giving this a 'shot'..! and congratulations!
I am still stuck at the main barrel. I am studying your file.
I wish you had left your original curves in the file so that I could see how
you went about making the shapes.
It is super encouraging to see that it can be done.
I will share my attempt as soon as I get some where : )
Please do re-post the file if you do the original curves in the file.
Speak soon.
Cheers.
8312.10 In reply to 8312.9
Hi
I keep stages in case I need to revert. As you will see I never keep all the lines (although I probably should). What I did a lot was use filet and variable filet. I started with the grips first and then the frame. I had to remake the frame after I mirrored it when having difficulty filleting one side and later discovered the gun is not symmetrical. I also foolishly did nit see that that profile of the rear of the slide has to match the upper rear part of the frame. I also found it hard to juge the depth of the frame at various points from the front.
I attach the only early version that has construction lines. Good luck.
Keith
8312.11 In reply to 8312.10
Thanks Keith, i really appreciate it the breakdown.
I have gone about it a different way, but i totally agree, it's not easy
and super tricky at different stages.
I ill share my progress on the forum before the end of the year hopefully. Lol!
Thank you again, especially for the files.
Cheers.
Sandeep.
8312.12
Hello everyone!
I know it's been a while! After asking for your help, I have been taking my time to
figure things out and try everything to make this model.
Attached is what I managed to do. Thank you so much for all the advise.
I cheated in some bits and improvised in others. It has definitely been a learning curve.
I know it's not perfect, but I will keep at it! Your comments are welcome!
Cheers.
Sandeep.
Next will be more romantic! :)
8312.14 In reply to 8312.13
Ha ha! I hope so! Thank you for the encouragement.
Cheers! Sandeep.
8312.15 In reply to 8312.12
That's turned out petty well Sandeep - Well done for sticking with it and for not giving in.
Matin
(TpwUK)
8312.16 In reply to 8312.15
Thanks Matin... it definitely tested me!
Cheers.
Sandeep.
8312.17 In reply to 8312.16
Hi
It has some challenging bits, that's for certain. I found that texturing in 3d Coat made a huge improvement to the final model that I made. I see that you used a different approach to modelling too. It turned out well.
Keith
8312.18 In reply to 8312.17
Hello Keith, yes it does have some very challenging parts. Thank you for your help and feedback!
Until the next one : ) Cheers.
Sandeep.
Show messages: All  1-4  5-18
