PolyBrush
 1-4  5-24  25-44  45-55
8301.25 In reply to 8301.24
Thanks Max!!!
If you are too intimidated by ZBrush Try Sculptris! (it's free) http://pixologic.com/sculptris/
An Moi UI spirit! :) A teal true gem!
Save as OBJ
Decimate with MeshLab (it's free) http://www.meshlab.net/
Save as OBJ
Import inside Moi with the genious _import obj by Max Smirnov http://moi.maxsm.net/media/files/ImportObj.v.1.5.2015.09.10.zip
Subdivide with _subdiv_beta9 by Max Smirnov http://moi.maxsm.net/media/files/Subdiv_beta9.zip
Makes anything you want with nurbs (here I made nothing :D
Export as OBJ
Render in the free Simlab Composer LIGHT its free (maxi 1920 *1040 ) Real Time render!
http://www.simlab-soft.com/3d-products/simlab-composer-freelicensee.php#light
Added just a little thing! :)
Have happy modeling!
EDITED: 16 Feb 2017 by PILOU
8301.27 In reply to 8301.22
Hi Max and thanks a lot for this very funny and useful script.
I just had told to Michael that I'm losing motivation on keep modelling with a 3D nurbs environment,
even with the superb Moi, and...here you are, with just another tricky script that ignited my imagination!
Thanks a lot Max!
I wanted to write a little modified version 1.0.1 that allows the selection of a source profile for the Sweep command.
If no source profile is selected then a factory Circle is used and the Diameter Input UI is displayed.
In the case of multiple source profile only the first selected profile curve is used for the Sweep command.
In the attachments you can find the file "Wire2.zip".
Unzip it and copy its content into the Moi's Command folder.
Here are a video and a screen capture :
http://take.ms/RPcb5
See you!
8301.28 In reply to 8301.26
Hi Pilou.
Thanks a lot for your suggestion but, as you can imagine, I already knew Sculptris for a long time and I've used it a lot some years ago.
But definitively no ZBrush for me :)
At least until Pixologic will decide to build a more consistent and less "crazy" UI for its flagship product.
I much prefer 3DCoat in (almost) all respects.
Ciao!
Sure 3D Coat is some more complete than Sculptris! :)
Else Sisley can transform some CADs in true paint! : ) (it's free) http://www.stat.ucla.edu/~mtzhao/research/sisley/
EDITED: 20 Apr 2021 by PILOU
8301.30
Wow, this discussion keeps getting more and more interesting!
Frenchy, merci beaucoup for the links and tips! I will definitely check them out thoroughly.
Marco, I can fully understand your choice for 3D Coat. It's a powerful ZBrush competitor, and I'm keeping a close eye on it, but I've already invested a lot of $ and time in ZBrush, and last time I tried 3D Coat (a few months ago), I concluded for myself that I still prefer the feel of ZBrush sculpting. It feels more fluid and natural, it's difficult to explain in words. :) But yeah, the ZBrush UI is an odd one, with all the tiny sliders and some other quirks, such as the unusual curves. I'm really looking forward to ZBrush 4R8, which will *finally* have a standard transform gizmo, although I've gotten reasonably used to working with the Transpose tool by now.
Max, you've once again proved your creative coding talent! Thanks a lot for the cool new tool!
Have a great weekend you all,
— Metin
metinseven.com — 3D (print) models • animation • characters • icons • illustration • infographics • visualization
Translating the wire2 and test it I don't find Diameter on the result!
Does this normal ?
Edit sorry : that's normal as I had first choose a profile! :)
8301.32 In reply to 8301.31
the Sisley download link no longer works...
8301.33 In reply to 8301.32
@Stefan
Send me a MP :)
French version of Wire2 by Marco ;)
http://moiscript.weebly.com/scripts-de-max-smirnov.html
@Pilou
Done. :-)
Sweet! :)
8301.37 In reply to 8301.29
Hi Pilou.
The download link of Sisley (the Abstract Painter) is broken.
Where did you find the exe ?
8301.38 In reply to 8301.37
There was there where it must be but seems the link is broken!
So PM me!
EDITED: 17 Feb 2017 by PILOU
Version 1.6
8301.40
Can wire2 work with history ?
So if you move one of the objects the wires redraw
shayne
8301.41 In reply to 8301.40
Hi shayne, unfortunately no there isn't any way currently to have a point picked in this way get updated with history.
PolyBrush New version! 1.7 (there is a free version;)
http://polybrush.org/
EDITED: 8 Jun 2017 by PILOU
Show messages:  1-4  5-24  25-44  45-55
