Xtreme Network Curve & Flow on Surface
All  1-16  17-20
8288.17 In reply to 8288.15
Yep,
divide and conquer!
Swept top surface - helper surfaces for opening and outer contour (extruded) - blend between them - stencil top surface - blend between blend and cutted top surface.
You can't always get what you want
But if you try sometimes well you might find
You get what you need - Written by Keith Richards, Mick Jagger
Have a nice day
Karsten
8288.18
Thank you for your input - meanwhile - My interest is determining what are the limits as far as Moi3d can go to solve the problem, before I venture outside -
There is EvoluteTools D.LOFT http://www.evolute.at/software/software-overview.html
There is Wings 3D https://sourceforge.net/projects/wings/?source=typ_redirect
It would be nice to control the file / polygon count weight / size - some of my files are almost 2 million bytes~
The object is like those inflatable rafts - with a flat bottom - all one piece - top is an open rectangular frame, the hull is closed below.
I'll keep at it and let you know the results.
8288.19 In reply to 8288.18
If you want try a new "Subdivide" program maybe this new one can help you! (in its free version)
It has a direct bridge in the two ways with Moi! :)
Rocket 3F : https://rocket3f.com/
8288.20
Warning: Possible humor, lingo may not be spot-on:
It can be done, however, there are other issues i.e. fitting a bevel into the opening. This is how it's done:
1. Line up centered and symmetrical *helps three closed curves
2. Not *too far apart - it can be stretched or scaled later
3. Make a *fishhook from the edge of the top opening frame all the way around - about 100 ribs - open curves
4. The *fish hook if you want a rounded edge, with a 'long' stem
5. Attach the stem to a *point, which is centered on the back, or bottom level
6. Best to drag points from the tail of the fish hook to the center point
7. Make sure everything is spot-on - connected
8. Loft *from a quad on the top closed curve - using 100 or so *depends square polygon(? lingo - those little square surfaces!) sufaces & 'Uniform'
9. Wire-cut the loft (choose 'closed')
10. Remove the SURFACE
11. Fine tune the 'mesh' points, clean and align if necessary - adjustments
12. Network, top & back rail - then all the 'ribs' (open fish hook curves)
Then you have it! I'll post something later to show
Humberto Quackenbush
Show messages: All  1-16  17-20
