Loxodrome script for Sphere
All  1-2  3-7
8281.3 In reply to 8281.2
Reminds me of a bighorn sheep!
8281.4
Guys, I installed and tried the Loxodrom script and managed to get the top port of the spiral to connect to the vertical line but can't get the bottom part to do the same. I've played around with the parameters like whorls, etc. but nothing moves the bottom part. Any suggestions?
Thanks again!
Gunter
EDITED: 15 Jul 2024 by GUNTER511
8281.5 In reply to 8281.4
Hi Gunter,
My previous reply got zonked by windows internet connection and work distraction...
I do not think that I understand your question.
The loxodrome curve on the sphere is asymptotic with respect to the North and South poles.
It would take an infinite number of whorls to reach the poles.
The _loxodrome01 script can be run a second time with Top unchecked, to generate the bottom half, Southern Hemisphere curve.
The bottom half could be scaled in the top view, to meet the South pole, with the bottom curve still tangent to the top curve (per test),
but the bottom curve would no longer be a loxodrome.
8281.6 In reply to 8281.4
Hi Gunter, another way to make a spherical spiral is to take an arc and run the Transform > Deform > Twist command on it, see here:
http://moi3d.com/forum/index.php?webtag=MOI&msg=8144.1
8281.7 In reply to 8281.6
That worked, yay! And super easy.
I think the problem was I wasn't twisting enough and so It looked like the spiral was on one side but with a much greater angle of twist it's in the middle.
Many thanks as always!
Gunter
Show messages: All  1-2  3-7
