MassModding the Stock SloLow GUI
All  1-10  11-16
8276.11 In reply to 8276.10
Hi Ced, see here for how to do the viewport borders:
http://moi3d.com/forum/index.php?webtag=MOI&msg=7804.2
8276.12 In reply to 8276.11
Thank you!
Here's the finished GUI & the ViewportForeground.png - it's here: C:\Program Files (x86)\MoI 3.0\ui
Bon Voyage!
Julio
EDITED: 25 Jan 2017 by FRACTIONALIST
Size: 18.3 KB, Downloaded: 28 times, Dimensions: 53x95px
Size: 225.4 KB, Downloaded: 72 times, Dimensions: 900x506px
Size: 309 bytes, Downloaded: 28 times, Dimensions: 33x33px
8276.13 In reply to 8276.12
Hello,
If you can speak frankly, mostly every custom MoI UI I've seen so far ends to look like this :
Except maybe File/Save/Undo/Redo/Delete icons that might looks a little bit dated, I find all the other icons gorgeous, and the global readability really good ... even after 10-12 hours of usage.
I kinda like the 'happy' atmosphere from the actual version, something that I'm myself surprised.
Just want to share an other pov, because despite the first look, MoI default UI is much better than many software's I have used ... probably a matter of taste, or a clever design ... but definitively something that should be respected ;)
8276.14
Like I said in another post, offer a STANDARD install or a CUSTOM installation where you can checkbox the scripts, shortcuts & nodes you'd like to install, as well as offer a SAVE WORKSPACE for custom setups & GUI SKIN options - which would add exponential VALUE to Moi3d!
I'm not thrilled to install all these nodes - fearing messing up what I've already cobbled together after a month of mining this forum.
8276.15 In reply to 8276.14
Maybe you could create a backup of your MoI folder before going further in your customization process ?
I don't know how mac os files structures works. On windows, everything is in the MoI install folder (C:\Program Files (x86)\MoI 3.0), and the .ini + keys are in C:\Users\"username"\AppData\Roaming\Moi.
8276.16
PaQ = alright - I'll do that and see what happens - let you know - thank you.
Show messages: All  1-10  11-16
