How to do this? Plse some help.
All  1  2-10
8275.2 In reply to 8275.1
Hi Rudy,
With two long curves, they can be extruded and the top 2 edges Blended.
Your curves have several sections, and only two long ones are desired.
I deleted everything except the bottom curves. Place a point to preserve extrude distance, or remember the height.
Trim the two extreme rounded ends in the middle with two points.
Save only the long curvy side, and rebuilt it to get rid of "corner" type points near the 2 ends. I used .001 tolerance.
Then mirror the long curve.
Extrude the two long curves.
Select the two top EDGES and BLEND. Blend can be adjusted.
Planar the bottom, and Join all 4 surfaces to a solid.
BlendCap script is another way, with the correct single top edge.
EDITED: 31 Jan 2019 by BEMFARMER
8275.3 In reply to 8275.2
Thank you Brian!. Very much appreciate it.
So far, it sounds turk to me.I will look into it.
Rudy
Another different result depending of what you need! :)
Take the 2 top sinuous curves : draw an Arc perpendicular at the middle between them
then Network
If top is too "flat" add some arcs before Network :)
Here just 3 arcs
EDITED: 23 Jan 2017 by PILOU
8275.5 In reply to 8275.4
Thank you Pilou.
8275.6 In reply to 8275.5
here's one.....
8275.7 In reply to 8275.2
Thank you.
Is there any chance you can do a step by step visual (with a printscreen shot). Still cannot understand well the procedure.
if it is too much, never mind.
Rudy
8275.8 In reply to 8275.7
Apologies, Rudy, but I lack the skill and time.
Michael, Burr, and others are both highly skilled and excellent at such "tutorials."
8275.9 In reply to 8275.7
Hi Rudy, are you getting stuck on a particular one of the steps that Brian wrote about above? If so please mention which one it is and I can give you more details on that one.
8275.10
Hello Rudy,
Here is a Sweep and Blend result. By the way, your linework is very clean.
Waves
EDITED: 2 Feb 2025 by OSTEXO
Show messages: All  1  2-10
