Fillet problem
All  1-3  4-11
826.4 In reply to 826.1
Filet problem II (head light), see result, when object is Solid.
Example head light, cut from SolidBox
make attention to your geometry,
BestReg`s EDDI
Message 826.5 deleted 10 Aug 2007 by ANDRAS
826.6 In reply to 826.4
Hi Eddi!
There is a diffrent between your example file and my MOI files.
You have "Cap ends" but I have not "Cup ends". Why?
826.7 In reply to 826.6
I realised that the projected curves have not "Cup end".
is it would be a bug?
826.8 In reply to 826.6
Hi Andras,
The "Cap ends" option will be hidden if there is not at least one closed and planar profile curve.
So possibly the points of your profile curve have been disturbed slightly in z so that they are not flat planar curves, or they are not quite all the way closed.
826.9 In reply to 826.7
Ah, well probably these projected curves are not planar - that's why no cap ends option for them.
At some point in the future I would like to try to automatically cap more complex ends, but it will be a while before that will be possible.
826.10 In reply to 826.9
I understood
Thank You!
826.11 In reply to 826.10
Ok,
Here very simple examples for "cap ends", (results surface only)
Useful or not`?, possible in conjunction with other Commands
(StraightSnapON, ObjectSnapON)
TrimCommand__Add trim points__Done__select new edges__use BlendCommand "value 0"
(observe seam, there must trimpoint get set, other trimpoint opposite)
TrimCommand__Add trim points (4points added)__Done__select new edges__use NetworkCommand (observe seam)
two trimed edges + line__LoftCommand used
SweepCommand used__edges is profil__middle line is rail (ShowPointsON)
__SweepOption End: PointyEnd__after "Done"
__Top most point selected__ moves to middle
BestReg`s EDDI
Show messages: All  1-3  4-11
