Fillet problem
All  1-9  10-11
826.10 In reply to 826.9
I understood
Thank You!
826.11 In reply to 826.10
Ok,
Here very simple examples for "cap ends", (results surface only)
Useful or not`?, possible in conjunction with other Commands
(StraightSnapON, ObjectSnapON)
TrimCommand__Add trim points__Done__select new edges__use BlendCommand "value 0"
(observe seam, there must trimpoint get set, other trimpoint opposite)
TrimCommand__Add trim points (4points added)__Done__select new edges__use NetworkCommand (observe seam)
two trimed edges + line__LoftCommand used
SweepCommand used__edges is profil__middle line is rail (ShowPointsON)
__SweepOption End: PointyEnd__after "Done"
__Top most point selected__ moves to middle
BestReg`s EDDI
Show messages: All  1-9  10-11
