3d connexion 3d mouse not working
All  1-10  11-16
8204.11 In reply to 8204.10
yes michael they do... :-)
8204.12 In reply to 8204.11
Hi torsten, if the window movement glitches go away after you've finished moving, that should not really cause any difficulty itself in using the program. I know it looks gross but that's going to fall into the "cosmetic" category and it should be resolved with v4.
Can you describe a bit more about the jumpy mouse problem though? I haven't heard about that one before and that sounds like it could impact work.
8204.13
when you orbit with the mouse and make small movements it kind of jumps more than you actually move...
8204.14 In reply to 8204.13
Hi torsten, does it only happen during view orbiting? What about other mouse things like drawing?
Does the jump look like the mouse cursor gets larger for a moment? Maybe you're running into this new OS feature: https://www.tekrevue.com/tip/cursor-bigger-shake-to-locate-el-capitan/
Try going to your Mac system settings under System Preferences > Accessibility > Display and turn off "Shake mouse pointer to locate", does it go away after that?
8204.15 In reply to 8204.14
hi michael,
no I turned that feature off already, as far as I see its only while orbiting the mouse...
cheers
t.
8204.16 In reply to 8204.15
Hi torsten, that's too bad I was hoping that was it.
Unfortunately right now I have no idea what you're running into with that - I have not been able to observe any differences in mouse orbiting behavior while running on Sierra over here, nor heard anything about it from any other users as of yet. Maybe if more people run into it I'll be able to find a common element and narrow down the cause.
Hopefully it's another glitch caused by using X11/Wineskin and will be solved by v4's native Mac build.
Show messages: All  1-10  11-16
