How to approach this model
All  1-2  3-7
8177.3 In reply to 8177.1
Hi matur61, CAD programs like MoI are mostly focused on modeling precise shapes like machined parts, with much of the shape defined by 2D profile curves. The shape you're trying to do there is very different than that, organic forms like that are a much better fit for a polygonal modeler rather than a CAD program. Something like ZBrush or 3D coat would be much more suitable tools for that than MoI.
8177.4 In reply to 8177.1
Hello Matur,
maybe with a loft - starting from a point. Switch on the control points of the curves and move in x, y and z.
Have a nice day
Karsten
Hi matur61,
maybe something like this... You draw some wave lines in Photoshop, Gimp etc. save it as .bmp and then use the freely available ZSurf (for Windows, which runs also under Wine in OS X) which saves as .iges.
8177.6 In reply to 8177.1
Hi matur61,
As Michael said it's not so easy attempt to do that kind of stuff with a Nurbs modeler like Moi,
and maybe it doesn't make much sense.
But just in order to give you and idea, I'll show how to achieve something similar in Moi with a couple of great Max Smirnov's scripts.
Here's the link to a video capture of a little test I did Moi : http://take.ms/18mOK
And here's the zip archive containing the stuff that I have used : http://take.ms/25j6J
I have used Moi V3 for Windows and only these commands :
1) HeightMap : Max's script
2) PatternSelection : Max's script
3) Rebuild : standard Moi command
4) Loft : standard Moi command
After extracting the zip archive you will get a "commands" folder and the "height_001.png" file.
Copy the file contained into the "commands" folder into your Moi's "commands" folder.
Put the "height_001.png" file wherever you want.
N.B. If your are a Windows user you need to run Moi in administrator mode in order to use the "HeightMap" script.
Or at least, this is what I need to do with my Moi.
This is just an example and you can play with different pngs or different settings for Rebuold or Loft commands,
or you could try to use also the Network commands instead of loft, but in this case you need to generate both curves (x and y) with the "HeightMap" script.
Have a nice day.
8177.7
Thanks a lot for the ideas and for the time dedicated.
Show messages: All  1-2  3-7
