Gosper curve
All  1  2-6
8176.2 In reply to 8176.1
How about polyarrow as a name for a polyline with directed line segments?
Or polyvector.
So a directed line segment is a "vector," more or less.
EDITED: 13 Nov 2016 by BEMFARMER
Updated markdown document.
Understanding of poly line segments improved.
MoI lines have start and end points already!
Orient line/line command will likely be perfect for the script...
The Orient line/line command can do copy, scale, and align.
interesting read. I attach for you a Peano Gosper Curve with more iterations. Maybe you find it useful. It is done with Shade3D vers. 12 and a preset from Mr Toshiaki Katoh's Math Modeler, which you would probably love... (unfortunately OS X only).
If you want to take a look what his Math plug-in's for Shade3D can do:
http://www.ne.jp/asahi/t/katoh/
it is under the Scripts section and the first link is for the videos.
Best Regards
8176.5 In reply to 8176.4
Than you Stefan
8176.6 In reply to 8176.1
This gosper curve script uses OrientLineToLine, rather than turtle graphics or L-Systems.
One gosper curve polyline is created, for the current Level.
The maximum level is 5, which takes about 2 seconds. Modifying the code would permit level 6, which takes about 12 seconds.
Level 7, which consists of 823543 line segments, failed to process. Maybe MoI version 4 would process it?
After the script is done, the polyline can be converted to a control point curve, with the script _PolyCurveToCurveBeta.
The script demonstrates scripting.
Documentation may be re-written.
Show messages: All  1  2-6
