Placing spheres on knots/vertices
 1-3  4-23  24-39
8166.4 In reply to 8166.3
You're welcome Marco!
8166.5
Hi Stefan, thanks a lot for the advice.
I guess this is exactly that what I've been looking for.
I'm going to test this script and show off the results later.
Best regards, Martin
8166.6 In reply to 8166.5
Hello Martin,
you can also use the node editor for that. Use nodeeditor.v.0.85mod3.zip. First construct/curve/intersect all lines. You will get the point objects. Let the points selected and create a point node under Test/Point. This point version evaluates the coordinates of all points. Now create a solid/sphere and an transform/orient node. And wire them. Ready for run:-)
Have a nice day
Karsten
You're welcome Martin!
I'm curious what you will create!
8166.8 In reply to 8166.1
There is a script in the MoI resources page under petr's MoI page, under custom commands called CopyToPoints...
This achieves the first part of what you need.
Lacking is the ability to use a "magnitude" with the points... I can do it randomly with the randomize script, but to "control the value specifically", Needs that method added somehow....
8166.9
Thank you guys. Great community here!
@Karsten
I read interesting things concerning the node editor. I will check it out.
@Stefan
To be more concrete according my project.
I have a file from a finite element mesh incl. outer and inner nodes with specific outer loadings for each node stored in the file.
As mentioned above, I want to place a sphere in each node paramterized with the outer loading (stress value).
After that I want join all neighbouring spheres with cylinders and perform a boolean operation.
At the and I'm going to perform a retopo operation to gain somekind of a metaball like structure (can be done in Cinema4D too via workarounds).
The aim is to generate a lightweight structure for solid real world workpieces made of selective laser melting/sintering.
You will hear from me.
Thanks for the explanation Martin, sounds interesting!
8166.11 In reply to 8166.6
Thanks Karsten
Now it is clear to the use of your new Node ....
have a nice day
al
Size: 422.4 KB, Downloaded: 118 times, Dimensions: 1920x1080px
8166.12 In reply to 8166.11
Yep!
... and an individual scaling is also possible now:-)
Have a nice evening
Karsten
8166.13
Hi Martin,
As Karsten stated, this is easily achieved in node editor.
Select your net, then "ShowPts" Copy/Paste points.
In Node editor place Object/Selected to capture point array.
To adjust scaling alter num string in "Const" node.
This is the perfect exercise to start exploring parametric design in MOI.
-James
P.S. Of course all the numerical inputs could be dial widgets
for total parametric control. See attached screen grab below.
EDITED: 14 May 2019 by JFH
Size: 126 KB, Downloaded: 51 times, Dimensions: 972x570px
8166.14 In reply to 8166.13
Hi James
By placing in a timely manner
points and working with ranges and interpolated
you get something near Metaballs (GH)
very interesting
best
al
Size: 300.2 KB, Downloaded: 64 times, Dimensions: 1920x1080px
8166.15 In reply to 8166.9
Hello Martin,
can you post an example of the fea file-format?
Have a nice day
Karsten
8166.16 In reply to 8166.15
Hi Karsten.
Yes I can do it.
Unfortunatelly at the earliest on Friday, have a lot of other stuff to do.
I'm going to use this tool for meshing.
Non commercial version allows only 1000 nodes, however for a proof of concept this is satisfactory.
http://www.visualfea.com/download.htm
Best regards,
Martin
8166.17 In reply to 8166.16
Hello Martin,
I've made a short test with the 3dSolid example and exported the result to txt. Unfortunaly the output seems not to give loads (x,y,z-forces) for all fea-nodes. Afer an reorder in libre office I saw some gaps?! That makes parsing more difficult. Is it a uniquely job?
Have a nice day
Karsten
8166.18 In reply to 8166.17
Hi Karsten,
nope the routine has to be performed for different geometries/models after the proof of concept was successful.
I will check (FEA node export) this during the next days.
I performed a similar operation last year while using an export from ANSYS result txt-file (x-y-z & forces) and used this input in Cinema 4D for meatball modelling.
It worked very well for each node.
Best regards,
Martin
Message 8166.19 deleted 9 Nov 2016 by KMRQUS
8166.20 In reply to 8166.18
Hello Martin,
sounds interesting:-)
I've written a node to import text/csv-files. And a first test looks good! Read back the xyz coords works good (pointarray), if you have the sequence separated in a csv-file. The node supports also numarrays but it can't parse for fea-node numbers and fill missing infos.
Have a nice day
Karsten
8166.21 In reply to 8166.20
p.s.: It sounds like a structural optimization algorythm for light weight structures!?!
8166.22 In reply to 8166.21
Absolutely! That is the plan.
It goes in similar direction like Altair OptiStruct, however with improved surface quality and total control concerning the primatives (spheres, cylinders etc.) that are used as base bodies.
I suppose that Moi3d can do that with a good performance. :)
Best regards,
Martin
8166.23 In reply to 8166.22
Hello Martin,
I'm also using fea for the job. I think it is a good choice to use the nodeeditor as a tool for that. Support of different geometries and different fea output formats are easy to handle, if some missing nodes are made. The mesh and output of calculix (.dat), openFOAM via ParaVIEW would be possible to support also. I don't have a look to ANSYS in the past, because I use the WB, but now I'm curious:-) I think it's also possible to select only the biggest joined object with a filter node. If you think a special script would do the job in a better way - the nodeditor can help to design the workflow and logic - the code can give you the examples.
Have a nice day
Karsten
p.s.: I've used in the past: CALCULIX/NETGEN, CATIA GPS/GAS/ANL, OpenFOAM (flow), COMSOL (magnetics/heat transfer/flow), ANSYS(mechanical/thermal/CFX) (it seems that i'm an old man) - but I've never heard VisualFEA before? What is the reason/advantage to choose this tool?
Show messages:  1-3  4-23  24-39
