New Aug-1 bug fix release available
All  1-9  10-15
815.10 In reply to 815.9
Thanks a lot for the patch! I've been testing this object again, and a few others that
were giving similar problems, and it seems like it fixes that problem with Join.
I've tested the same operations with and without the patch, and I can see clearly
the difference. There's no need of scaling, and no holes either.
I'll keep testing just in case I find any problem with it.
About the segments continuity thing... do you think it would help (and it would be possible)
to specify the angle of tolerance... like a way to avoid the automatic refinement and let it be
spedified by the user. Like give it a margin in that angle of tolerance to keep the same number
of segments along a curved surface.
I'm not sure how that operation works, so maybe what I'm saying doesn't make any sense :)).
In any case, I know you have other priorities and still, you'd have to thing about that to see what
the side effects would be.
Again Michael, thanks a lot!!
Jacobo.
815.11 In reply to 815.10
Hi Jacobo, that's great news! Thanks for testing that. I will use this update for Join then. I'm not sure if I will put out another beta or not yet, if not then this will be in there for V1 though.
I've tried having a margin for the angle before, but in the simple case what happens is an angle of 20 degrees with a margin of 5 degrees ends up being the same thing as an angle of 25 degrees. It basically just pushes the same thing to happen elsewhere.
One thing that I have thought about is to use a margin as a post-processing step after all subdivisions were complete. Maybe I could scan through and look for areas that had been subdivided just once from the initial base mesh, and glue those back together if the glued-together piece was within the margin angle tolerance. I think that might be the best way to clean up these areas. But I won't have time to experiment with that for the initial V1 release though, I have put this on my list of stuff to tune up later.
Here's an image to show you why these kind of subdivisions happen in the first place:
Without subdivisions, you can see that it would be hard to capture the detail for that little bump. It would be very wasteful to cover this entire surface with an evenly divided mesh that was small enough to capture that bump. Putting in subdivisions allows the mesh to gain detail only where it is needed.
The same thing is happening to that one fillet in your other model - it becomes more tightly curved in that one area in the middle (I think it was a variable-radius fillet), so MoI applies the same kind of logic to it to subdivide it to try and capture the detail of the curvature there. That's why it happens right now anyway.
815.12 In reply to 815.11
It's great that you have put that in your list! It would be great to have a way
to clean up more those areas. It would be great to have it as an option.
Thanks a lot for taking that into account to be included in a future version of MoI.
Keep testing!
Jacobo.
815.13 In reply to 815.9
>>MoI will only attempt to join together edges that pretty close together - within a maximum of 0.005 units
Hmmm... it is different than the Join command in Rhino... there it is a two times of global modeling tolerance, isn't it.
Could you include all of this "accuracy" specific information into the MoI's help file? I admit, most of users don't need to know that, but many Rhino's users are suckled on technical terms...
I remember you mentioned three kind of tolerance so far.
Global modeling: 0.001 units
Rebuild tolerance for Loft and Sweep with Refit option: 0.01 units
Joining tolerance: 0.005 units
Petr
815.14 In reply to 815.13
Hi Petr, that's a great idea, I will include this with the help file.
I put up a new patch for this Aug-1 build here: http://moi3d.com/beta/Aug1_patch2.zip
This fixes a few meshing bugs and a few other assorted bugs.
To install the patch, unzip to get moi_lib.dll and just copy that over top of the old version in the Aug-1 version in \Program files.
EDIT: One other file also needs to be patched, copy the Sweep.js attached here over top of the old version in the \Commands sub-folder to make Sweep options work.
EDITED: 19 Aug 2007 by MICHAEL GIBSON
Show messages: All  1-9  10-15
