Clear Javascript in Memory
All  1  2-5
8139.2 In reply to 8139.1
Hi Mindest,
If I understand correctly you could solve your problem with this setting in the [UI] section of your moi.ini file :
[UI]
DisableFileCaching=y
Best,
Does F5 do anything?
8139.4
Thanks for the responses... I will try in the next few days and provide feedback.
Thanks to everyone!
8139.5 In reply to 8139.3
F5 won't do anything but the setting Marco writes above will do it - by default every text file that MoI loads from disk, including .js files, are cached in memory once they have been loaded so if they are run again they don't have to be read from disk a second time. Setting DisableFileCaching=y will disable that so that all text files are loaded fresh each time and that should solve the problem.
Show messages: All  1  2-5
