dimple
All  1-2  3-6
8137.3 In reply to 8137.2
Does this help
Dimple is made with a ball mill
Would you also tell me how to do it?
thx Marv
Size: 82.6 KB, Downloaded: 34 times, Dimensions: 855x693px
8137.4 In reply to 8137.3
Hi Marv, there are a couple of different ways - you could create a sphere and then draw a horizontal line in the front view and trim the sphere by the line to make a dimple surface, or you could rotate your arc you have there by 90 degrees in the Front view, and then run the Construct > Revolve command. In the Revolve command, set the Angle to 180 and uncheck "Cap ends" before placing the axis points:
Or another way is to draw a 90 degree arc in the front view and revolve it by 360 degrees to make your hemisphere.
If you don't need to make a hemisphere, I'll probably need to see a clearer image because the one you posted above seems very fuzzy and I can't really see anything there.
8137.5 In reply to 8137.3
Marv
Do you mean like this?
And this?
Barrie
AH ok! A capsule?
The more funny is this one! ;)
Draw your cylinder
Kill the top face
Cut in twice the top circle
Select the 2 arcs circle
Call Transform Blend Function!
Play with the cursor slider or input values
(you can use negative values for "inside" dimple! )
EDITED: 20 Oct 2016 by PILOU
Show messages: All  1-2  3-6
