Java Update 8 - Moi 3D V3 on MAC OSX Yosemite 10.10.5 - start failure
8136.1
Hello Michael, since tomorrow I got a Java update to version 8, MOI 3 no longer starts under normal conditions - only in the test mode of wineskin. But then the menu bar below is missing
What can I do?
wineskin Version: 2.5.8
engine: MoiWine 1.3.32
Here the error message when Testrun in wineskin:
fixme: d3d: init_driver_info Unable to find a driver / device info for vendor_id = 0x1002 = device_id 0x68b8 for driver_model = 2
fixme: win: EnumDisplayDevicesW ((null), 0,0xe4f99c, 0x00000000), stub!
fixme: win: EnumDisplayDevicesW ((null), 0,0xe4d110,0x00000000), stub!
fixme: keyboard: X11DRV_ActivateKeyboardLayout 0x4070407, 0000: semi-stub!
fixme: d3d: resource_check_usage Unhandled usage flags 0x8.
XIO: fatal IO error 35 (Resource temporarily unavailable) on X server ": 5010"
after 474 requests (474 ​​known processed) with 0 events remaining.
Thanks for your help
moritzbock
Size: 1.9 MB, Downloaded: 29 times, Dimensions: 800x605px
Size: 1.4 MB, Downloaded: 21 times, Dimensions: 800x450px
8136.2 In reply to 8136.1
Hi Moritz, the white toolbar problem looks like it's because you're running MoI v2.52 there and not MoI v3. The CustomUI that you've installed there requires new functions that are in V3, the error is saying that it can't find a function because it did not exist yet in v2.52 .
Please make sure you are getting the latest v3.1 version, you can download it by putting in your license key here: http://moi3d.com/reinstall.htm , that might help with your startup issue as well.
Let me know if you're still seeing the startup problem with v3.1 .
8136.3 In reply to 8136.2
you're right - I was using the version V 2.5 - for whatever reason - grumble!!!
Now it works great with MOI V3.1
Thank you so much
moritzbock
