FAILED simple Fillet
All  1-10  11-12
8132.11 In reply to 8132.10
Ok thanks michael!
I guess the other side of that is peoples particular setup and job at hand...
So i work in "inches".... But if i start modeling a 175 foot object (or i guess sci fi guys modeling 1000 foot spaceships), things start moving away from world zero...
Does changing my unit system to feet or meters or miles change that initial interaction with "how far away from zero" i am?
Is there something like a "scaled environment" where i could start a project with an initial declaration that i will be modelimg at "a larger scale"? (I guess that would mean i couldnt model detail then, because it was expecting BIG stuff, side effect......)
8132.12 In reply to 8132.11
Hi Burr,
Yes, if it means you'll be using small numeric values, like say x = 10 in meters rather than x = 10000 in mm. But the only thing that matters is the number itself, that you're using less digits in the number values.
Well there is an automatic mechanism that adjusts calculation tolerance to be a percentage of the object size so it adapts to the current object being operated on. But that's a somewhat different issue than losing fractional precision in arithmetic because of larger numeric values being used in coordinates.
Show messages: All  1-10  11-12
