hotkey to toggle Show pts
All  1-2  3-5
8119.3 In reply to 8119.2
Hi co3Darts,
> This script is simple and just a if not check? Why is this not possible for geometry?
> I don't know javascript so I'm clueless
> script:moi.geometryDatabase.getObjects().getCurves().setProperty( 'hidden', true );
That script is set up to work on a list of objects which is what getCurves() returns. In order to do what you want you would need to access one individual curve out of the list so you can look at its hidden property.
Try this:
script: var crvs = moi.geometryDatabase.getObjects().getCurves(); if ( crvs.length > 0 ) crvs.setProperty( 'hidden', !crvs.item(0).hidden );
8119.4
Thank you Michael! Much appreciated and for Geom it appears the .getBReps() grabs solids and surfaces?
script: var geom = moi.geometryDatabase.getObjects().getBReps(); if ( geom.length > 0 ) geom.setProperty( 'hidden', !geom.item(0).hidden );
I'm new but need to scripting for Moi3D but have used it off and on for several years. 3 years later it's working as I like :)
Jason
8119.5 In reply to 8119.4
You're welcome Jason! And yep .getBReps() will indeed get solids and surfaces.
Show messages: All  1-2  3-5
