hotkey to toggle Show pts
All  1  2-5
8119.2 In reply to 8119.1
In the same light. I can tell there is no core command in moi like ShowPoints for ShowSurfaces or ShowCurves. I use Maya most of the time and have mel scripts that toggle various geometry classes which I would like to have for curves and surfaces in Moi. Right now I have shortcut keys for this but it's not a toggle, it just turns them off
using this inline script
http://kyticka.webzdarma.cz/3d/moi/#HideCurves
http://kyticka.webzdarma.cz/3d/moi/#HideSurfaces
e.g. script:moi.geometryDatabase.getObjects().getCurves().setProperty( 'hidden', true );
How can I write a simple if else to turn hidden to false or true for the various geometry types so the script works as a toggle instead?
this script is else format
script:var dir = moi.view.lightDirection; if ( dir.x == 1 && dir.y == 1 && dir.z == -1 ) { dir.set(-0.5,1,0); } else { dir.set(1,1,-1); } moi.view.lightDirection = dir;
I'm trying to wrap my head around this to combine each. The 1st is a command with no var (variable) then I'm wondering if I can put the result of ('hidden', var(variable))
script:var dir = moi.geometryDatabase.getObjects().getCurves().setProperty ( 'hidden') ==! 1 then moi.geometryDatabase.getObjects().getCurves().setProperty ( 'hidden', false)
Something like above but I do not know how to get the correct syntax or test for if that is true or false and cast into the var variable?
This script is simple and just a if not check? Why is this not possible for geometry? I don't know javascript so I'm clueless
script:moi.view.showHiddenLines =! moi.view.showHiddenLines;
Thank you!
EDITED: 30 Mar 2019 by CO3DPRINTS
8119.3 In reply to 8119.2
Hi co3Darts,
That script is set up to work on a list of objects which is what getCurves() returns. In order to do what you want you would need to access one individual curve out of the list so you can look at its hidden property.
Try this:
script: var crvs = moi.geometryDatabase.getObjects().getCurves(); if ( crvs.length > 0 ) crvs.setProperty( 'hidden', !crvs.item(0).hidden );
8119.4
Thank you Michael! Much appreciated and for Geom it appears the .getBReps() grabs solids and surfaces?
script: var geom = moi.geometryDatabase.getObjects().getBReps(); if ( geom.length > 0 ) geom.setProperty( 'hidden', !geom.item(0).hidden );
I'm new but need to scripting for Moi3D but have used it off and on for several years. 3 years later it's working as I like :)
Jason
8119.5 In reply to 8119.4
You're welcome Jason! And yep .getBReps() will indeed get solids and surfaces.
Show messages: All  1  2-5
