Tip: Try centroid triangulation for better ZBrush meshes
 1-17  18-23
Non-centric vs centric ? Does it make any difference when exporting STL for 3D printing?
8109.19 In reply to 8109.18
Hi Ed,
Good question. I don't know if the two triangulation methods only divide quads in a different triangular way (then there would be no or almost no visual difference in the polygon structure), or if they each result in a visibly different triangular polygon structure.
I hand over the microphone to Michael for this. :)
8109.20 In reply to 8109.18
Hi Ed, centroid triangulation shouldn't make any difference for 3D printing - ZBrush seems to be sensitive to the triangle structure.
But one thing that I think is good for both ZBrush and STL export is to use the "Divide larger than" option which will chop up anything larger than the distance you put in there. It can be good for both of these exports to try and avoid having triangles span a large distance across the object, it tends to make the triangulation more apparent in the final result. ZBrush needs a finer level of dicing though.
8109.21 In reply to 8109.19
@Metin, this setting won't change how quads are triangulated, just n-gons which you'll get at trimming boundaries.
8109.22 In reply to 8109.15
Hi glmr,
> very useful feature! just can't find moi.ini
> where it is?
There's a button that will tell you where it is and also open it up for you under Options > General > "Edit .ini file" :
8109.23
Thanks for the additional info, Michael. Only Ngons are triangulated of course, not quads, my mistake. And I tend to forget the presence of the button shortcut to the Moi.ini file, thanks for that reminder too.
— Metin
metinseven.com — 3D (print) models • animation • characters • icons • illustration • infographics • visualization
Show messages:  1-17  18-23
