Moi 3.1 and macOS Sierra
All  1-11  12-16
8101.12 In reply to 8101.10
Hi Rick, another thing you can try to see if it helps is to install the latest XQuartz from here: https://www.xquartz.org/ and then change the setting in MoI for it to use the system installed XQuartz rather than the bundled one as described here: http://moi3d.com/forum/index.php?webtag=MOI&msg=6967.4
8101.13
I did restart the system after trying the first two tweaks.
The last one - of installing newer Quartz, appears to have done the job - I now get a title bar with window controls that work, but it gets launched from a bash window that stays on-screen.
Oh well, at least it's a workaround that restores the function - Thanks.
8101.14
Unfortunately, while it solves one oissue, ot creates another. Because it is running from a XQuartz parent, the Edit menu does not apply to MOI - you cannot copy/paste objects in MOI.
Now the question is how do I get Editing functions back?
8101.15 In reply to 8101.14
Hi Rick, what about Cmd+C for copy and Cmd+V for paste, or MoI has Copy/Paste buttons on the Edit section of the side pane.
8101.16
Right you are - the shortcuts of Cmd+C and Cmd+V do work, and I had completely missed the Copy/Paste icons in the sidebar.
Thanks. Looking forward to v4.
Show messages: All  1-11  12-16
