Moi 3.1 and macOS Sierra
All  1-10  11-16
8101.11 In reply to 8101.10
Hi Rick, did you restart your machine after changing the "Displays have separate spaces" setting?
Unfortunately there is not any fix available for it yet in the library that MoI 3.1 uses.
8101.12 In reply to 8101.10
Hi Rick, another thing you can try to see if it helps is to install the latest XQuartz from here: https://www.xquartz.org/ and then change the setting in MoI for it to use the system installed XQuartz rather than the bundled one as described here: http://moi3d.com/forum/index.php?webtag=MOI&msg=6967.4
8101.13
I did restart the system after trying the first two tweaks.
The last one - of installing newer Quartz, appears to have done the job - I now get a title bar with window controls that work, but it gets launched from a bash window that stays on-screen.
Oh well, at least it's a workaround that restores the function - Thanks.
8101.14
Unfortunately, while it solves one oissue, ot creates another. Because it is running from a XQuartz parent, the Edit menu does not apply to MOI - you cannot copy/paste objects in MOI.
Now the question is how do I get Editing functions back?
8101.15 In reply to 8101.14
Hi Rick, what about Cmd+C for copy and Cmd+V for paste, or MoI has Copy/Paste buttons on the Edit section of the side pane.
8101.16
Right you are - the shortcuts of Cmd+C and Cmd+V do work, and I had completely missed the Copy/Paste icons in the sidebar.
Thanks. Looking forward to v4.
Show messages: All  1-10  11-16
