Replace Closed Curves With Circle
 1-16  17-21
8080.17
Hello,
Does it possible to create a similar script that changes closed curves with circle to nearest integer value from the specific range? For example I type range from 2 to 6, curves closest to this values (from 1,51 to 6,50 in this case) are change with nearest integer value circle, assign any unique styles group by value and the rest outside the range are hide.
Sorry for my English, I hope it's understandable.
Thank you in advance for your help.
8080.18 In reply to 8080.17
Possible? I think Yes.
Augment the script with .htm file to select some or all closed curves,
and also to request the desired range of "dist" (dist = box.diagonalLength;), as distMin, and distMax.
distMin and distMax can be any value, not just integers.
Filter the selected closed curves with "dist", as follows:
If a closed curve's "dist" value is outside of the range, do not process that closed curve.
If a closed curve's "dist" value is inside the range, process that closed curve.
modify factory.setInput( 3, (Math.sqrt(dist*dist/2)/2));, by applying
Math.round(Math.sqrt(dist*dist/2)/2)),
or Math.ceil(), or Math.floor(),
to get the circle's radius in an integer value.
8080.19 In reply to 8080.18
Heh :-). Thank you Brian. I'm not a programmer but I understand idea and I'll try translate your helpful hints into a complete script. Trial and error method :-).
Marius
8080.20 In reply to 8080.19
Maybe combine and modify RCCWC.js, lineweb.js and lineweb.htm, and maybe some other script...
Looking forward to your new script.
8080.21 In reply to 8080.20
Math.round is best option but I had to move the closing bracket
from
to
Math.round(Math.sqrt(dist*dist/2))/2)
Thanks again :). I'm trying to take next step, but for me it is sci-fi :-D. Your support helped me a lot.
Marius
Show messages:  1-16  17-21
