Make2D 4 views script
 1-2  3-22  23-27
8041.3
Thank you Michael, its very usefull. Make2D 4 views + Max Dimensions = happy user : )
Have you an image of what made this Make 2D for 4 views ?
Major Grubert from Moebius ?
8041.5 In reply to 8041.4
Hi Pilou, so for example if you select an object like this:
When you then run the script, it will generate 2D curves in the Top view like this:
So it generates all 4 views in one go, while the regular Make2D command can only do one view at a time. In the future I want to make an "All views" option in Make2D and PDF/AI/DXF export but until then this can help.
8041.6 In reply to 8041.5
Hi Michael...
How about the invisible lines...? Usually appear as a dash line.
Thanks..
8041.7 In reply to 8041.6
Hi Anis, when you run the command there is an option for whether to generate invisible lines or not. To enable it, turn on this checkbox here:
When enabled the hidden lines will be assigned to a style named "Hidden lines". If you export to Illustrator you can look for that layer to set up dashed line styles.
Ok! Thx for the infos!
8041.9 In reply to 8041.8
Hello Pilou, you guess it right, its a Moebius character name. Cheers
8041.10 In reply to 8041.9
@ Michael
French version : curious i had nothing to translate! Does this normal ?
8041.12 In reply to 8041.11
It's normal for this particular case since it was able to re-use the prompts from the Make2D command which you have already translated.
8041.13 In reply to 8041.12
thx! :)
8041.14 In reply to 8041.13
Excellent script, Michael!
Thanks a lot.
Mik
8041.15 In reply to 8041.14
Great script but when i add _dimensions on all shape created by, the perspective have not the reel dimension :(
i need to _dimensions make translation ^^automaticaly
8041.16 In reply to 8041.15
suis je le seul à vouloir coter la dessus ?
im the only one that try to make dimensions on this 4 view ?
8041.17 In reply to 8041.15
Hi Dzeko,
The 3D view gets converted to 2D by a projection method and it's just part of how projection works that an angled projected line does not have the same length as the original line.
You can try putting in the dimension in the 3D model before you run Make2D so the dimension text and arrows are all part of the process, or if you need better dimensioning than that you should try some different CAD programs that have focused more on that specific area than MoI has as of yet. Try ViaCAD for an inexpensive solution.
8041.18
Super sweet script Michael G.!
Michael T.
8041.19 In reply to 8041.5
Hi Michael
Thanks for this new fonction .
In the future , perhaps , you can you add an option to choose between american or européen views like next picture .
Chri
8041.20 In reply to 8041.1
Thanks so much Michael.
This will be so useful for architectural details.
eric
8041.21 In reply to 8041.19
Hi Chri, I would like to do a more full featured drawing generation in the future.
Do you happen to have any example models along with 2D drawings generated from them similar to the diagram you show? Any examples like that for me to reference and compare against would be helpful in the future when I get a chance to work in this area again.
8041.22 In reply to 8041.21
hi Michael
here are 2 examples in JPG and MOI.
I hope i have understood what you would like !
best regards
Chri
EDITED: 10 Aug 2023 by CHRI
Size: 63.2 KB, Downloaded: 128 times, Dimensions: 798x609px
Size: 91.4 KB, Downloaded: 100 times, Dimensions: 1149x682px
Show messages:  1-2  3-22  23-27
