Make2D 4 views script
 1-10  11-27
@ Michael
French version : curious i had nothing to translate! Does this normal ?
8041.12 In reply to 8041.11
It's normal for this particular case since it was able to re-use the prompts from the Make2D command which you have already translated.
8041.13 In reply to 8041.12
thx! :)
8041.14 In reply to 8041.13
Excellent script, Michael!
Thanks a lot.
Mik
8041.15 In reply to 8041.14
Great script but when i add _dimensions on all shape created by, the perspective have not the reel dimension :(
i need to _dimensions make translation ^^automaticaly
8041.16 In reply to 8041.15
suis je le seul à vouloir coter la dessus ?
im the only one that try to make dimensions on this 4 view ?
8041.17 In reply to 8041.15
Hi Dzeko,
The 3D view gets converted to 2D by a projection method and it's just part of how projection works that an angled projected line does not have the same length as the original line.
You can try putting in the dimension in the 3D model before you run Make2D so the dimension text and arrows are all part of the process, or if you need better dimensioning than that you should try some different CAD programs that have focused more on that specific area than MoI has as of yet. Try ViaCAD for an inexpensive solution.
8041.18
Super sweet script Michael G.!
Michael T.
8041.19 In reply to 8041.5
Hi Michael
Thanks for this new fonction .
In the future , perhaps , you can you add an option to choose between american or européen views like next picture .
Chri
8041.20 In reply to 8041.1
Thanks so much Michael.
This will be so useful for architectural details.
eric
8041.21 In reply to 8041.19
Hi Chri, I would like to do a more full featured drawing generation in the future.
Do you happen to have any example models along with 2D drawings generated from them similar to the diagram you show? Any examples like that for me to reference and compare against would be helpful in the future when I get a chance to work in this area again.
8041.22 In reply to 8041.21
hi Michael
here are 2 examples in JPG and MOI.
I hope i have understood what you would like !
best regards
Chri
EDITED: 10 Aug 2023 by CHRI
Size: 63.2 KB, Downloaded: 128 times, Dimensions: 798x609px
Size: 91.4 KB, Downloaded: 100 times, Dimensions: 1149x682px
8041.23 In reply to 8041.22
HI
actual methodology :
Size: 29.5 KB, Downloaded: 83 times, Dimensions: 484x568px
Size: 31.3 KB, Downloaded: 68 times, Dimensions: 488x567px
Size: 33.2 KB, Downloaded: 82 times, Dimensions: 655x341px
Size: 29.7 KB, Downloaded: 49 times, Dimensions: 249x605px
Size: 26.6 KB, Downloaded: 74 times, Dimensions: 490x568px
8041.24 In reply to 8041.23
Hi Chri, thanks very much for the examples!
So if I understand correctly, you're currently getting this done by setting up that diamond with 9 copied objects in it and then applying the proper rotations to each object?
Would it perhaps be better to automate that object copying and transformation process with a command that generated 9 objects from one, rather than having it do Make2D output only? Because then you'd have a few more options like being able to export to PDF or AI format to get the shaded background underlay, or doing Make2D on the Top view in just one more step... ?
Also for your methodology, how is the size of the diamond determined?
8041.25 In reply to 8041.24
hi Michael
Perhaps the size of the diamond could be a parameter for the "automatic layout" generation .
( in a first time , it can be for example (part size) x4 if the part is cubic ).
I think , that , like in all Cad program , you need to choose and ajust the best views during the dimensionning .
The final result can't be automatic. ( "automatic layout" is only a step before manual final layout ).
Chri
EDITED: 29 May 2020 by CHRI
8041.26 In reply to 8041.25
Hi Chri, for long pieces maybe it could be possible to err on the "more spacing" side by using the maximum of width or height to make each cell size.
But does an object duplication and rotation mechanism sound like it would do the job for you? Like select an object, run an "AutomaticLayout" command, and it generates your diamond of 9 copied and rotated objects for you, then you can Make2D or export to PDF as you see fit.
8041.27 In reply to 8041.26
Yes , Michael , i agree with your explanation . it will do the job .
Perhaps , it could be a good way , to wait others users opinions !
Chri
Show messages:  1-10  11-27
