Making undeformable circles?
All  1-5  6-11
8038.6 In reply to 8038.2
@ Brian & Marco - it's not really necessary to do that type of arc construction, the circles that you create in MoI will already be made of 4 precise non-approximated arcs.
But when you turn on control points, it is assumed that you want to squish those points around and MoI will show you the points of a rebuilt circle that deforms smoothly rather than devolving into 4 arcs with sharp cusps between them.
The exact 4-arc circle will only be replaced by the deformable version if you actually edit any of the control points.
The same thing happens with surfaces of revolution as well.
8038.7 In reply to 8038.6
I didn't know about this behavior.
Thank you very much for your explanations!
Ciao.
- Marco (mkdm).
8038.8 In reply to 8038.6
8038.9 In reply to 8038.1
Hello 3image,
at the end every circle is represented as a nurb curve in modern CAD. The number of control points isn't a criteria to decide if it is exact or not. The magic here is the knot vector. You can find a very good desciption for that on page 9 in the following document: http://digiitalarchfab.com/portal/wp-content/uploads/2011/03/Nurbs-Curve-A-Guide-for-the-Uninitiated.pdf
Have a nice day
Karsten
Enlighting!
8038.11 In reply to 8038.9
A more legible copy of the article is here:
http://www.hcs.harvard.edu/~lynders/cs275/NURBCurvesForUninitiated.ps
Show messages: All  1-5  6-11
