Switch between views
8027.1
Hello guys!
I would like to have a shortcut for each view - so that I would be able to switch between Top, Right etc. quickly. How would one go about doing that?
/Nick
EDITED: 16 Jul 2016 by BLINDFOLDJUMP
8027.2 In reply to 8027.1
Hi Nick, check out here for what to put in for the "command" part for each shortcut key for setting up keys to switch between views:
http://moi3d.com/forum/index.php?webtag=MOI&msg=3808.2
8027.3 In reply to 8027.2
Awesome Michael, thanks a lot!
8027.4
Hi Nick
here is a script that you can save as a shortcut key, I use the "space" key that will maximise whichever view the mouse pointer is over
its a very fast way to get the view you want 2nd press on space sends the view back to all 4 .
script:if ( moi.ui.mainWindow.viewpanel.mode != 'split' ) { moi.ui.mainWindow.viewpanel.mode = 'split' } else { var viewport = moi.ui.getViewportUnderMouse(); if ( viewport ) { viewport.viewPanel.mode = viewport.name } }
cheers
shayne
8027.5 In reply to 8027.4
Ah thanks a lot Shayne, that's very useful!
8027.6
Reviving this old thread, to ask if there's a command or script to toggle a view under the mouse pointer to the opposite view?
So if my pointer is over a top view (either full screen or a quad view) and I activate the command or script, the view will switch to the bottom view.
Thanks in advance!
─ Metin
visualizer • illustrator • 3D designer — metinseven.nl
8027.7 In reply to 8027.6
8027.8 In reply to 8027.7
Exactly what I meant, thanks for the always swift reply, Michael!
─ Metin
