Reset view?
All  1-5  6-10
8025.6 In reply to 8025.4
I want to ask if there's a way to always reset the view around all visible elements.
I use this script to isolate an object and then focus on it:
moi.geometryDatabase.isolate(); script:moi.view.resetAll();
I get a non-consistent results when I run the script again to get out of the isolation mode and focus on the whole scene because, even if other elements are now visible, the re-focusing will be around the selected object if I change the camera and I don't deselect it before pressing the script.
I want the script to be able to isolate and focus on a selected object to quickly inspect it for example, and pressing it again would get me out of the isolation mode and focuses on everything that is now visible so I can inspect another element.
Thank you,
- Flowgun
8025.7 In reply to 8025.6
Not the most elegant solution since I'm not a programmer (yet), but I was able to achieve what I want by inverting the selection, focusing, and then inverting the selection back again. This is my new script to isolate selections:
script: /* Isolate selection */ moi.geometryDatabase.isolate(); script:moi.geometryDatabase.invertSelection(); script:moi.view.resetAll(); script:moi.geometryDatabase.invertSelection();
I hope I get a reply for a more elegant code though =D
Cheers.
8025.8 In reply to 8025.6
Hi Flowgun, by default the view reset will fit to selected objects and if you run it a second time it will fit to all objects regardless of selection.
But you can pass in an optional parameter to the resetAll() function to make it behave differently. The parameter can be one of:
'auto'  - Do automatic toggle between selected or all.
'selected'  - Only reset to selected objects.
'all'  - Only reset to all objects.
'default'  - Reset to default startup views, keeping reversed views (bottom/back/left).
'harddefault'  - Reset to startup views and get rid of reversed views (bottom view will become top).
So you can use it like this for example: moi.view.resetAll( 'selected' );
Message 8025.9 deleted 20 Mar 2022 by FLOWGUN
Message 8025.10 deleted 20 Mar 2022 by FLOWGUN
Show messages: All  1-5  6-10
