close caps?
8019.1
Hello. just trying to make close surface from network of lines, but have no idea how to fill holes. any idea?
Size: 44.5 KB, Downloaded: 82 times, Dimensions: 644x347px
8019.2 In reply to 8019.1
Hello glmr,
depending on what you want:
- cut with plane and trim
- make a line from seam edges of the surfaces and make a sweep with the edge of both surfaces
- make a blend between the edges of the surfaces
If the stuff is not confidential, the best choice is to post the 3dm - maybe there are some better solutions for your special case.
Have a nice weekend
Karsten
8019.3 In reply to 8019.1
Hi glmr,
As a first simple and straightforward test you could use the "blend" command.
Select the first two edges on the same side of both sufaces and run the "blend" command.
Then, select the two surface edges on the opposite sides.
Ciao.
Marco (mkdm).
Size: 174.5 KB, Downloaded: 70 times, Dimensions: 1576x968px
8019.4
Thank you!
8019.5 In reply to 8019.1
Hi glmr, also if those ending curves are coplanar you can build a planar cap surface by selecting them and running Construct > Planar.
It's difficult to tell things like if they are coplanar just by looking at a screenshot so that's why it is helpful to post the 3DM model file with your objects in it instead of only a screenshot.
8019.6 In reply to 8019.5
thank you! already tried and it works
