General technical questions about v3 Moi's API
 1-3  4-23  24-26
8010.24 In reply to 8010.20
> factory.generateVertices();
> var corners = factory.getCreatedObjects();
How can I get the x,y coordinates of a corner?
var factory = moi.command.createFactory( 'fillet' );
factory.setInput( 0, objlist );
var points = factory.getCreatedObjects();
factory.cancel();
for ( var j = 0; j < points.length; j++ )
var pnt = points.item(j);
moi.ui.alert( "pnt = " + pnt);
moi.ui.alert( "pnt.x = " + pnt.x);
moi.ui.alert( "pnt.y = " + pnt.y);
___________
I tried to treat it as an array as well... no luck so far.
-- Mindset
8010.25 In reply to 8010.24
Hello Mindset,
try something like this: points.item(i).pt.x
pt is a mathPoint (moi.VectorMath.createPoint())
var pnt = points.item(j); gives you an PointObject (visible Object like a line or a cube) that has a mathpoint inside:-) the mathpoint has x,y,z
I hope that helps.
Have a nice day
-Karsten
8010.26 In reply to 8010.25
Wunderbar!
Du bist eine kräftige Stimme
THANK YOU very much, Kersten.
-- Mindset
Show messages:  1-3  4-23  24-26
