New Jul-25-2007 version available now
All  1-4  5-9
799.5
When I make an export in Illustrator format from 3D view, it seems that an orthogonal projection of the model is generated. Would it be possible to have an option for a perspective projection as well (to have an exact "copy" of the curves as they appear in the 3D viewport in MoI) ?
Below is an example of the current results when I superpose a MoI screenshot and the .AI file in Photoshop.
Thx
799.6
Hi Michael, could the Untrim command also work on particular selected edge and not only with full selection of surface boundary edges? -Petr
799.7 In reply to 799.6
Hi Petr, I would like to do that eventually, but it is not quite a simple thing to do. It will have to go on the wish list for a future verson.
799.8 In reply to 799.5
Great eye! Thanks for catching this, I had actually intended for it to be the same as the 3D view but there was a bug messing it up.
It ended up being a perspective view, but stretched in one direction by an amount relative to the aspect ratio of the viewport. If your viewport happens to be fairly square like mine it is hard to see, if you have a somewhat wider more rectangular viewport the distortion will be more pronounced.
I should be able to fix this up a bit later tonight, I'll get this in for the next bug fix beta later on this evening.
799.9 In reply to 799.8
Slight delay in plans - I'm going to postpone the new beta until tomorrow afternoon so I can add some additional diagnostic stuff for this one big remaining script error problem.
Show messages: All  1-4  5-9
