I can't bevel simple object
All  1  2-5
7962.2
you can see the problem if you split your object into 3 solids and then chamfer.
Chamfer the parallel ends then select edges and join Loft and then Boolean join the 3 objects.
Or chamfer the tapered middle then extrude ends.
Hope this helps.
Barry
7962.3 In reply to 7962.1
Hi skycastle - although it looks simple, it's more difficult for the fillet engine to process than it first appears. The way fillets (and also chamfers) works is by calculating an arc of a specific radius, but that arc will be a longer or shorter segment depending on what angle different surfaces meet each other. So that means that when you have surfaces that meet each other at different angles, the fillet or chamfer surfaces between them will be of different sizes and the fillet engine seems to be having problems trimming the different sized pieces with each other in your case here.
It tends to be easier to fillet things if you fillet everything that meets at a juncture point instead of only some edges - that gives the fillet or chamfer some space to put in a corner juncture patch where things meet up.
For now I'd recommend using the method Barry shows above.
7962.4
Thank you both. This makes sense as a work around and I will use this in Moi. As a side note, I'm able to create this bevel in another app but I prefer to stay in Moi all the time. Is there any chance of the chamfer having some additions made to handle these sorts of cases?
Thanks again.
7962.5 In reply to 7962.4
Hi skycastle,
Yes, I hope to improve it in the future.
Show messages: All  1  2-5
