Does anybody here know the what's happening here?
All  1-3  4-8
7961.4 In reply to 7961.1
Hi Keith, it's difficult to tell what might be going wrong just from screenshots alone. Is it possible for you to post the 3DM model file of one of the more simple structured solids that is not getting normals going the right way?
If your solid has anything like self intersecting surfaces or degenerate surfaces that are tiny collapsed slivers, those are some of the things that can tend to confuse the mechanism that creates outward facing normals for solids.
7961.5 In reply to 7961.4
Hi Michael
Maybe you never sleep?
On exporting just crashed too. Maybe coincidence.
Keith
7961.6 In reply to 7961.5
Hi Keith, thanks for posting the 3DM file, I will take a look at it. Can you also please send me the moi_report11.zip crash report file as well? You can e-mail that to me at moi@moi3d.com .
7961.7 In reply to 7961.5
Hi Keith, so the problem seems to be some messed up edges in this scalloped out area here:
I separated out the surfaces for that area, then untrimmed and retrimmed them, and then rejoined them to get it fixed up, it looks like the fillets there end just very slightly off alignment from the closed surface seam for the scalloped surface and that was confusing the joining process, I had to join things back in a particular order to get that spot to work ok.
Please try the attached 3DM file and see if that works better for you now. And if you can send me the crash dump report for the crash I might be able to see what's going on with that too.
7961.8 In reply to 7961.7
Thanks for your suggestions Martin and Kevin, I did try both and although neither worked this time they were new things for me to learn. Michael fixed things overnight. Great customer support, thanks Michael.
While casting about for solutions yesterday I noticed that Moi is not on the Blender Wiki list of computer modelling programes. Seems a bit of an oversight.
Best wishes
Keith
EDITED: 22 May 2016 by KEITH1961
Size: 2.3 MB, Downloaded: 113 times, Dimensions: 1024x576px
Show messages: All  1-3  4-8
