project moi3d v4
 1-4  …  25-44  45-64  65-84  85-98
Hi everyone,
As a side note to my previous post (http://moi3d.com/forum/index.php?webtag=MOI&msg=7954.63),
and talking about the great workflow that Michael has developed for Moi,
i'm testing a combined workflow involving the new polygonal + SDS software Rocket3F from Istonia and Samardac (currently in beta),
in conjunction with Moi.
It seems really a great marriage !
I know, that rightly, Samardac does not collect high esteem in this forum, but i must admit that its collaboration with Istonia (the creator of NVIL)
is showing very good results.
Moi + Rocket3F (or NVIL) + Max's subdiv script = GREAT THINGS !!
Ciao !
EDITED: 8 Sep 2016 by MKDM
7954.66 In reply to 7954.65
Rocket3F has a fruity UI! That is refreshing!
7954.67 In reply to 7954.65
Never heard of Rocket3F but I know Nvil. So is Rocket some kind of successor to Nvil or what's the partnership all about?
7954.68
Agree with PaQ:pre-order to support Michael
M
7954.69
I would pre-order, too. Michael does indeed a fantastic job with MoI!
7954.70 In reply to 7954.67
Hi 3image,
Yes, Rocket3F is a form of successor to NVIL and it's based on NVIL core engine.
The description of the project is readable in : https://rocket3f.com/team
Ciao!
7954.71 In reply to 7954.64
Hi PaQ,
> The pre-order idea was just to give a little bit of support (money), as it seems the
> amount of work needed for this new version is way over the initial scope.
I really appreciate this, but I'm just not comfortable taking money for something that's not ready to go and that doesn't have a firm date set yet. I like to keep things loose and flexible but taking pre-orders could end up impacting that. I mean like what if for example some really good idea seems within reach but ends up making for an additional 2 year long beta release period to work things out really well? (that's not necessarily the plan, just a reasonable "what if")
I think I end up with fewer problems in the long run by doing things sort of in the reverse way from pre-orders - by that I mean trying to get a release really nailed down and only start actually selling it after that has happened.
But I certainly appreciate the sentiment and the vote of confidence anyway though! :)
Money can't speed up imagination! Only passion! ;)
7954.73 In reply to 7954.72
Only passion? No! As a mostly vegan living man - ( black coffee + cigarettes ) I know it better;-)
7954.74 In reply to 7954.71
Michael,
Considering your initial display engine was a 4 YEAR project..... i am grateful you undertook the 64 bit task.
Thanks again. Keep plowing brother!
Burr
7954.75
Maybe there could be a pay per command version.
Like a cent per line, 2 cents per circle, 3 cents a trim, 10 cents a boolean !
Show off your 3.99$ model !
:D
Marc
New beta version of Rocket 3F and first tutorial
Bridge between Moi working! Rocket <--> Moi in the 2 ways ! (just oriention importation from Moi so a little Rocket bug ;)
EDITED: 12 Sep 2016 by PILOU
7954.77 In reply to 7954.76
Hi Pilou, if it uses .obj files for the transfer there is an option in MoI under Options > Import/Export > "OBJ options" > Orientation, which if you change to the other value may solve your orientation problem.
7954.78 In reply to 7954.77
Yes it's was that i found also but not possibility to test because there is some glitch on the install of the bridges!
In my case it was working only one time! :)
I presume that is normal for a beta! ;)
7954.79 In reply to 7954.77
I've been following Integritywares Cyborg3d and fooling around with Powersurfacing for Onshape to get the Combined SDS holy grail. They seem to be making some great advances.
Does you kernel explorations take you away from them? You had mentioned your future interest in getting these types of toolsets in MoI. Is this the type you've investigated?
Random questions.... Thanks!
7954.80 In reply to 7954.79
Hi Burr, well I'm currently more interested in more robustness in the traditional CAD side of things like better fillets and shelling, I'm not yet investigating sub-d modeling integration as of yet. That is something that I want to pursue in the future but only after the regular mechanical type CAD stuff is further refined in MoI.
I would not be surprised if I end up using more than one kernel to do different things in different areas, at least for quite some time.
7954.81 In reply to 7954.80
By all means. For sure!
Thanks for the reply.....
7954.82
Hi Mister Burr,
I can't find any price for this 'Power Surfacing for Onshape' product Oo ... do you have any info about that ?
7954.83 In reply to 7954.82
Hey paq,
Right now free (limited in subd/nurbs surface quantity conversion... paid for full. When i get home i'll post what i know.
FYI: just download and run it to test.
But i just got off the phone with dave this morning. Onshape updated something with their api which broke the "connection" with send to and receive from onshape. Hoping its fixed pretty quick here.
7954.84 In reply to 7954.82
PaQ,
I think "paid" is just a license of cyborg3d, which is roughly rhino cost area (i could still be wrong)...
Also commenting on the api break thats being experienced, i think this is a future symptom of the "online, always updated" trend.... 3rd party guys will always get jacked and be playing catchup..
Show messages:  1-4  5-24  25-44  45-64  65-84  85-98
