What's the right method for merging complex solids together?
All  1-4  5-9
7953.5 In reply to 7953.1
Hi Phil, I've attached the result of a bunch of tricky trims of one piece against the other, starting with a trim of the voronoi piece against a 2D profile curve as shown above, and then extruding that 2D profile out and then the difficult trims of it as well. For the top surface I had some trim problems but since it was planar I was able to cut the edges where the crossed over each other and then build planar surfaces using Construct > Planar. This should hopefully give you enough to finish it off with a few more trims for slicing off the excess width and then joining in the rest of the surfaces to make it a finished solid. Let me know if you are still stuck with finishing it off.
Anyway, this is the main technique for difficult intersections, basically booleans are a combination of surface/surface intersections and then trimming with the pieces to discard automatically figured out by what volume they are contained inside of, followed by an automatic Join. You can kind of almost think of booleans as a sort of automated "batch mode" of trimming. For complex things where the booleans are getting confused, you can instead work with manual trimming and joining at the surface level instead.
The type of thing you had with a lot of overlapping surfaces tends to make for messy surface/surface intersections.
7953.6 In reply to 7953.5
Thanks a lot for your help. I will work on it tonight and try to finish it off. I originally "flowed" a flat voronoi solid ([SLD - Voronoi FLAT] against a curvy surface [SRF - Flow] to make the shape I need (in a manner similar to the Voronoi Chair tutorial). This is how I ended up with all these complex cross-connections. I don't know if I should have approached this differently...
Phil
7953.7 In reply to 7953.6
Phil,
It's the "skimming" surfaces that Michael describes that is giving you heat.... Here's a video where I adjust some curves and cut your part.
So in the video you see me "raise the bottom curve" by a very slight amount, so it's not barely skimming through the entire bottom of the chair. The vertical curve is adjusted but you cant see it in the video. I used my "super nudge" command which moves .01mm. So I moved that vertical curve .04mm deeper into the solid to get a clean cut....
"""""""""""" I don't know if I should have approached this differently..."""""""""""""""
What you can do in the future, is model the veronoi with the base "much deeper, or thicker", then in this Boolean operation, cut the back to specs with your curve. Booleans are good to have a "complete intersection".............
7953.8 In reply to 7953.6
Hi Phil, re:
Well, the thing Burr mentions about having pieces that punch just partway through the other rather than skimming would have helped...
Also it would usually be good to do the boolean before doing the flow instead of doing it afterwards... But in your case here it's a bit more complicated since you have 2 pieces branching off in different directions, so I'm not quite so sure.
7953.9 In reply to 7953.7
@BurrMan (and Michael) - Thank you so much for having taken the time to share your knowledge on these issues. The various explanations and the excellent videos really helped me to understand (a little bit) more about what I need to do to finish this model. I am very, very grateful!
All the best
-Phil
Show messages: All  1-4  5-9
