Problem with fillet-factory in JS/Nodeeditor
All  1-2  3-5
7949.3 In reply to 7949.1
So for a script to get worker process isolation for the filleting, instead of calling factory.calculate() you would instead need to call factory.update() to begin the asynchronous calculation, then call factory.getCreatedObjects() which will wait until the asynchronous update completes and gives you back the result, then call factory.commit().
7949.4 In reply to 7949.2
Hello Michael,
thanks for your quick response and the details. So I will have a look to improve my radii-calculations to avoid that crashes or give up the idea.
Have a nice day
Karsten
7949.5 In reply to 7949.3
Hello Michael,
thanks again - I will try that. And I found also the bug in my radius-calculations:-) The 2.6 radius should be avoided by a function and so I knew, where I had to look!
Many thanks - the tips can improve the stability alot!
Karsten
Show messages: All  1-2  3-5
