Problem with fillet-factory in JS/Nodeeditor
All  1  2-5
7949.2 In reply to 7949.1
Hi Karsten - it does look to me like a radius value that is too big - are you trying to fillet the inside corners? Those can go only up to a radius of 2.3 or so, while you have a radius of 2.6 in the crash dump.
The reason why it does not crash under regular MoI operation is that in the regular Fillet command the fillets are calculated asynchronously in the moi_commandprocessor.exe process and if they crash the crash is isolated to that worker process and not the main MoI process. In your case here it looks like it's calling Factory::calculate() which runs directly in the main process and will not be protected by the worker process isolation (if I remember right).
You may not want to call filleting in this way because it tends to not be very stable with bad inputs like radius values that are too large to fit in the available space.
7949.3 In reply to 7949.1
So for a script to get worker process isolation for the filleting, instead of calling factory.calculate() you would instead need to call factory.update() to begin the asynchronous calculation, then call factory.getCreatedObjects() which will wait until the asynchronous update completes and gives you back the result, then call factory.commit().
7949.4 In reply to 7949.2
Hello Michael,
thanks for your quick response and the details. So I will have a look to improve my radii-calculations to avoid that crashes or give up the idea.
Have a nice day
Karsten
7949.5 In reply to 7949.3
Hello Michael,
thanks again - I will try that. And I found also the bug in my radius-calculations:-) The 2.6 radius should be avoided by a function and so I knew, where I had to look!
Many thanks - the tips can improve the stability alot!
Karsten
Show messages: All  1  2-5
