any advice about modelling this shape
All  1-2  3-11
7944.3 In reply to 7944.1
I'm thinking: Separate the different parts. Sweep each with a circle.
Use Blend Cap for ends. Use N-Sided for intersections, and/or Blend.
Remove top half with a plane.
- B
just tested it myself (again after a long time)... You need only to apply the gaussian blurr once. If you do it multiple times you get hill like results in some areas, while once only applied it's fine.
https://www.behance.net/futagoza
EDITED: 30 Oct 2016 by STEFAN
7944.5 In reply to 7944.4
There is also a script named Heightmap in MoI to do the same thing.
7944.7
Hi guys, thank you so much for the help.
and futagoza (STEFAN) please can you share ZSurf script for mac i only find exe file or link.
Finema , Frenchy Pilou (PILOU) i try high map script look good but i am missing the round shape in the bottom part of my maze anyway thank you guys really.
bemfarmer, thank you
7944.8 In reply to 7944.7
Hi albehany,
i run ZSurf via Wine or WinOnX under OS X, since there is no Mac version available.
http://www.iphonetopics.com/windows-emulator-for-mac/
7944.9 In reply to 7944.8
Thank you
7944.10 In reply to 7944.8
The list is outdated. I tried both Virtual PC for Mac & Crossover Mac but none of them is working from my side. However, found Parallels Desktop working fine.
https://www.techwhoop.com/windows-emulator-mac/
7944.11
Hi Guys,
Or you've got Vector Magic Free
https://vectormagic.com/
Automatically convert JPG, PNG, BMP, and GIF bitmap images to true SVG, EPS, and PDF vector images online by simply uploading them. Real full-color tracing, no software to install and results are ready right away!
Hope it helps ;)
Show messages: All  1-2  3-11
