Rebuild curves : a possible way to get a seamless curve in order to create seamless surfaces
 1-10  11-24
7912.11 In reply to 7912.9
Hi Marco,
> But...i must admit that, although your indications were exhaustive,
> they are doubtless for anyone who's more experienced than me in the nurbs's world.
I mean that when a single line is extruded, it results in a plane surface, and it is represented internally by special type of surface sub-class which can simplify various calculations such as surface/surface intersection.
If you just extrude your original curve that are made up of lines and arcs, you will get these kinds of simple planes in the areas where lines were extruded.
In the case that you're trying to achieve, you will not have that type of structure, there will be just one general surface and it won't be represented by an analytic sub-class.
> I mean.....
> As i tried to express in my previous post
> (http://moi3d.com/forum/index.php?webtag=MOI&msg=7912.3),
> i thought that, as showed in the attached file example2.3dm and the relative picture,
Ok, but I'm not sure what that picture is illustrating - you've got 2 filleted results there, neither of which is ill formed, there isn't really any reason to consider the one with multiple segments to be worse than the other one...
Going through a bunch of hoops to generate the single surface one is not worth the time unless it solves some particular problem.
> the surfaces obtained without seams, or with the minimum amount of seams,
> are better suited for filleting or boolean operations, for example.
> Or that a surface without seam could be better rendered or could present a finer
> surface curvature continuity.
Well, maybe there is some confusion about the term "seams" - normally in NURBS modeling a "seam edge" is a special type of edge, one on a closed surface like a cylinder or sphere surface where opposite sides of the surface come together and touch each other. These can often times be awkward when it comes to filleting, especially for spheres.
But the things you are talking about trying to eliminate here are not "seams", they're just regular edges.
> Is it correct to think that, having less seams in a surface, could lead to be able to
> create things like fillets and blends, without the need of merging the edges ?
This is not automatically true in all cases, it depends on the particular situation.
For something that is made up of structured parts like a line and arc drawing that you are showing here, it is usually better to have a multi-face structure with one separate face for each line and arc, so that each surface can be represented by a plane or cylinder surface sub-class and utilize some more simple code paths.
For your case here, you would only want to eliminate all those edges if you were working around some specific problem, like there happens to be a tiny edge fragment left over after a boolean and that little tiny fragment was making it difficult to do filleting later. But those are things you would do just for the specific case that was causing the problem.
For the most general use case where you've got something structured with straight lines in it, I wouldn't recommend trying to eliminate the segmentation like you're asking about.
When you are doing a boolean with a sphere, that's a case where it can be helpful to position the sphere so the sphere's seam edge won't be sticking out just a tiny bit in the booleaned result.
But just because there are some cases here and there where it could help with avoiding fillet problem does not automatically mean that you should put a ton of effort into removing as many edges as possible on every single operation.
7912.12 In reply to 7912.10
@Marco
Thx for the explanation about the installation of script!
About your seams
just render an object with yours seams : you will see that they don't appear on your renderings! ;)
About the Max's script : can maybe useful when you want directly inside Moi a drawing with only surface + external / Internal edges ?
EDITED: 5 Apr 2016 by PILOU
7912.13 In reply to 7912.11
Michael, i would like to thank you for your deep reply!!!
Now i understand :)
> ...you've got 2 filleted results there, neither of which is ill formed, there isn't really any reason to consider
Ok....maybe for me it's only for aesthetic reasons.
Thank's for the clarification. It was necessary!
I feel relieved to know that it's not necessary to put a lot of effort in order to remove as many surface edges as possible!
Now, some minutes ago, i made a little test involving 2 solids generated starting from
a traditional joined curve, composed by 2 straight lines and an arc,
and the other one obtained from the first curve, on which i applyed the Max's script transforming it into a single curve.
Well....the result surprised me 'cause on the classic solid the "shell" command
didn't work.
In the attached .png i tried to recap all the steps of the test.
If you want to spent again some minute to clarify this behavior, i'll thank you.
Nice night,
Marco.
Size: 1.1 MB, Downloaded: 268 times, Dimensions: 1915x1030px
7912.14 In reply to 7912.12
Well....interesting consideration...i'll think about it!
Thanks!
Ciao,
Marco.
7912.15 In reply to 7912.13
Hi Marco, unfortunately the shell command in the geometry library is not very robust, there are a lot of things that can get it confused. There is probably some case where it's the reverse from what you show.
But it is true that shelling can be simplified with more pieces that match up naturally edge-to-edge, so if you are focusing on using that it may be worth a try. But really if you need to do a lot of shelling, MoI's shell function is probably not going to do the job for you in many cases, so you may need to do your shelling in some other program for now.
Another way you could make things easier for shelling could be to build more of your part all from one larger Loft rather than doing it in separate pieces and blending, if you want it to look like one large flowing surface. See the attached file where I used Loft with the Loft style = "Loose" option to build the starting piece.
7912.16 In reply to 7912.15
I took Marco's file from this post here:
http://moi3d.com/forum/index.php?webtag=MOI&msg=7912.13
And shelled it .1 (He said it failed)
Doing a drilldown selection of that top surface, the success or failure can be achieved by the selection position.
Not sure if that can help you find anything on your end or not.
7912.17 In reply to 7912.16
Thanks Burr!
7912.18 In reply to 7912.16
Here's an example of a failure with a simple fillet on a seamless curve.
Also, in most cases you'll find meshing for export works better leaving the seams as they are.
ymmv
7912.19 In reply to 7912.16
Hi Michael and BurrMan,
Thank you both for your help!
From Michael's previous post :
Thank you very much for your suggestions and for giving me a different point of view.
Now....a strange thing that, believe me guys, is driving me crazy!
From BurrMan's previous post :
Well....
I reloaded the file that i posted in http://moi3d.com/forum/index.php?webtag=MOI&msg=7912.13, and, worked on it many times....
As shown in this current attached picture (curveRebuild3_B.png), if i try to shell the original object marked as "Solid 1",
the shell command is always correctly performed, regardless of selected area on the top surface.
But...if i do the same thing on the cloned copy of the "Solid 1" the shell ALWAYS FAILS!!!
Also, like before, regardless of selected area on the top surface!!
WHY ?????
What the cloned object (copy...pasted or ctrl dragged from the original), has in it that leads the shell command to fail ???
At this point, i'm not understanding anything more...
Please help !!
Nice day to everyone,
Marco.
Size: 1.1 MB, Downloaded: 71 times, Dimensions: 1915x1030px
7912.20 In reply to 7912.18
Hi danperk (SBEECH),
and thank you for your help!
I wanted to do a try by myself and i got the results summarized in the picture example4_capture.PNG that i'm posting here.
In effect the shelling on the extruded object with no internal edges fails with a radius of 2 but works well with radius of 1.5.
I think that this behavior leverages on the internal more complex structure of the object without internal edges.
If i understood correctly Michael's explanations, in this case the internal edges, help Moi to achieving the task.
Nice day,
Marco.
Size: 1.3 MB, Downloaded: 179 times, Dimensions: 1910x1030px
7912.21 In reply to 7912.19
Hello Marco,
the problem is here:
I don't know which method you have used to create the blendings, but the highlighted edges are splited in three segments.(One big and two small ones left and right) Select the 3 edges, hit tab, type merge and Enter for both edges. Then shell:-)
Have a nice day
Karsten
7912.22 In reply to 7912.21
Hi Karsten (KMRQUS) and Michael,
and thank you very much for your help.
Unfortunately, this isn't the first time that i forget to check the topology of the edges, before continue to try to do what i want to achieve...
Then, i thank you Karsten for reminding me the existence of the Merge command :)
Now, it's not my intention to bore, you or Michael, with strange and unverifiable issues,
but i observed a strange behavior that occurs to the Shell command,
in relation with the position of the mouse pointer and the zoom level,
and camera position while confirming the input of the selected area for that command.
I made this tests on the same object indicated by Karsten, but without first executing the Merge edge command.
Well...sometimes the Shell command works and sometimes not,
depending on the zoom level and camera position in 3d view and
if the MOUSE POINTER IS OR NOT OVER THE SELECTED AREA THAT ACT AS STARTING POINT for the shell command.
Or, at least, this is what i'm observing.
Sad to say that i'm not able to reproduce this issue in a stable way.
If any of you want to try, please give me the chance to verify what i'm saying.
Is any of you is aware of this behavior ?
The zoom level in 3d view or the camera position and angle has some sort of influence to the Shell or other commands ?
Thank's for all and have a nice evening,
Marco.
7912.23 In reply to 7912.22
Hi Marco,
No, not as far as I know. It's probably some bug using uninitialized memory, bugs in that category can be difficult to reproduce and can exhibit semi random behavior.
7912.24 In reply to 7912.23
Thank's for your support.
Although it is a bug, i'm glad to know that is not a sort of strange influence involving the camera or mouse position,
and the normal execution of the commands.
Ciao!
Marco.
Show messages:  1-10  11-24
