how to fillet this one?
All  1  2-8
7911.2
Hi:hope to understand correctly your question,if not please forgive me :)
draw a circle radius 0.5cm
trim the curve using the circle
do it again
delete trimmed part
select both and hit -BLEND-
on FRONT VIEW seems ok or maybe not.....just an idea :)
M
Message 7911.3 deleted 30 Oct 2016 by STEFAN
7911.4
Thanks Mauro,
I know this technique, but I had other non planar curves in the design that I could simply fillet with the fillet tool, without problems, so I was wondering why this one did not work properly.
wim
7911.5
apparently, if non planar straight lines are filleted, it works, but if there is a smooth curve involved, the fillet tool does not work. 2 straight lines in a crooked angle are still planar, I realize now, even if they are not parallel with x, y or z.
7911.6
extrude -> fillet -> select edge -> copy -> paste
EDITED: 7 Mar 2022 by SMIRNOV
7911.7
that's a nice one (and fast too!), Max! thanks.
wim
7911.8 In reply to 7911.5
Hi Wim, yes for curve filleting the curves need to be coplanar. And like you figured out, they can be on any oriented plane not just ones aligned to an XYZ axis.
Show messages: All  1  2-8
