Spiral script 2D for setting out Corinthian capital scrolls
 1-12  13-32  33-36
7903.33 In reply to 7903.32
Thanks a lot for your clarifications regarding the "immediate script" folders.
Nice night,
Marco.
7903.34 In reply to 7903.21
Hi Brian
Regarding your spiral script, is there any way to have a non linear control over the parameteres like growth and ofset - see attached image for an idea of what I am trying to achieve - the yellow line is a standard spiral using your script and the red line is one where I have manually adjusted the spiral outer arm. I am wondering if its possible to use your script slightly adjusted to get closer to a mathematical pure solution for this, giving a slower start and increasing openness
When you push the standard spiral growth and ofset the outer arm becomes very flat
Not being a maths expert, but I am wondering if it is possible to have a non linear growth from one spiral 360 degree revolve to the next ? where the growth starts small but increases in a non linear way ? This growth could perhaps be controlled by a curved line giving very subtle growth control (maybe elliptical 1/4 section) or a %
This could also be applied to the Z direction depth growth, to give a non linear and more natural feel. I have achieved this by projecting from a 2D spiral line down onto a domed revolved surface
Best wishes
Andy
Size: 348 KB, Downloaded: 52 times, Dimensions: 983x484px
7903.35 In reply to 7903.34
Hi Andy,
I'll have a look later.
I had been studying a spiral using quarter arcs.
7903.36 In reply to 7903.21
Hi Brian
Having written my last message it occured to me that I could probably work a solution using geometry - see attached .3dm file, which works really well
Take a spiral from your original script and extrude it down to a point, then revolve a curve (to give a lense fisheye effect) and then use curve - intersect for the result
Going back and adjusting the revolved 2D curve gives a real time visual intersection so you can visually adjust to suit your requirements :-)
Best wishes
Andy
Show messages:  1-12  13-32  33-36
