wish : freeze/unfreeze brep edges when meshing
All  1-7  8-10
790.8 In reply to 790.7
"...it looks like you're talking here about increasing subdivisions for small edges into even smaller bits?..."
Exactly! :) Maybe i've been explaining it backwards. I guess what I'm ultimately looking for is a sub-setting of "Divide Larger than", where you can create a window to exclude those edges which exceed a certain length and also exclude those edges which are less than a certain length. so if i first meshed an object with a maximum edge length of "X", then it would give me an option to fuirther reduce any edge which is shorter than "X" until it reaches a second minimum length value. Although that sounds really complicated when explained like this. From a user's point of view, i would be very happy to just have a bias adjustment in the mesh dialog, and have Moi work it's magic behind the scenes... but if it's not possible then i understand...
jonah
790.9 In reply to 790.8
I don't really know how I would implement a bias adjustment... But maybe something will come up after letting it percolate for a while.
In general the angular threshold is supposed to be doing the general overall goal that you're asking for - less polygons in flatter areas, and more polygons in more tightly curved areas. Can you please post your example object so I can see why it is not working well in that situation?
790.10 In reply to 790.9
Hi Michael. sorry for the delay. I have nothing critical at the moment. But when i have a good example, i will send to you. For now, it's more of a generalized wish...
jonah
Show messages: All  1-7  8-10
